crower stroker kit vs. micropolish and balance crank?
Old 07-25-2006, 02:03 PM
gsr336's Avatar
Default crower stroker kit vs. micropolish and balance crank?
i want to know what will be better just going aftermarket with my crank? or just micropolish and balance my stock gsr crank? and im going turbo and what how much should i bore it out to? and what piston should i use?
Old 07-25-2006, 02:10 PM
Dueceification's Avatar
Default Re: crower stroker kit vs. micropolish and balance crank? (gsr336)
I personaly am not a crower fan because of problems with their products. Though more displacement = more power generaly speaking. Honda cranks do hold up pretty good unless your putting down some insane hp. I wouldn't bore you engnine on stock sleeves you just asking for it to crack. Also you should probaly more descriptive about your setup so people can help you. There is a lot of information already on honda tech if you look around a lil.
Old 07-25-2006, 02:15 PM
gsr336's Avatar
Default Re: crower stroker kit vs. micropolish and balance crank? (93b16hatch)
i want to fully build my whole block
Old 07-25-2006, 03:59 PM
Who is Mr Robot?
wantboost's Avatar
thats 2 completely different things youre talking about.
Old 07-25-2006, 04:04 PM
gsr336's Avatar
eventually ... it is... thats why im asking which one is better?
Old 07-25-2006, 04:05 PM
Who is Mr Robot?
wantboost's Avatar
ugh.
if you want more displacement, go with the stroker kit.
if you want to save money and keep the stock stroke, keep the stock crank
Old 07-25-2006, 05:03 PM
gsr336's Avatar
what kind of stroker kit i should get or any of you recremend? crower? or something else?
Old 07-25-2006, 05:05 PM
siblues's Avatar
I dont know what the crower kit goes for but you could always use an ls crank and rods with custom pistons for an oem stroker kit?
Old 07-25-2006, 06:10 PM
gsr336's Avatar
Default Re: crower stroker kit vs. micropolish and balance crank? (siblues)
well i can people been telling me that but i want as much hp as possible... cause right now money i dont care about i just want to take people heads but im just only working on my block right now
Old 07-25-2006, 06:11 PM
Who is Mr Robot?
wantboost's Avatar
im still ******* lost as to WHAT THE F UCK YOU ARE TRYING TO DO.
make up your damn mind... stock crank or stroker crank and go the expletive from there
Old 07-25-2006, 06:12 PM
siblues's Avatar
So if money is no problem then pick a good shop and tell them you want the sickest setup possible and start shoveling out some cash?
Old 07-25-2006, 06:17 PM
Boner_Ben's Avatar
I would stay away from the strokers if you are building a turbo motor. Sleeve the block and bore to 84mm and go with an LS crank, Crower/Manley/Pauter rods for an LS, and some good forged pistons.
Old 07-25-2006, 06:29 PM
siblues's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I would stay away from the strokers if you are building a turbo motor. Sleeve the block and bore to 84mm and go with an LS crank, Crower/Manley/Pauter rods for an LS, and some good forged pistons. </TD></TR></TABLE>
I totally agree and thats why that is what i did
Old 07-25-2006, 06:56 PM
gsr336's Avatar
alright thanks for the info i'll be taking my engine apart and get it bored prolly sometime next week or whenever
Old 07-25-2006, 07:04 PM
Boner_Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr336 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks for the info i'll be taking my engine apart and get it bored prolly sometime next week or whenever </TD></TR></TABLE>
You should send it out to get sleeved first. Golden Eagle, AEBS, Benson, Darton are just a few that come to mind.
Old 07-25-2006, 07:20 PM
gsr336's Avatar
how much is taht going to cost?
Old 07-25-2006, 07:27 PM
Who is Mr Robot?
wantboost's Avatar
1100 or so.
you cant bore stock sleeves to 84mm
Old 07-25-2006, 07:32 PM
CoreyR's Avatar
Default Re: crower stroker kit vs. micropolish and balance crank? (wantboost)
stock crank. have the motor sleeved. you said money isnt an issue so theres nothing more to discuss. send it to get it sleeved and then take it to a machine shop and let them do the rest.
96halx
07-14-2009 08:14 AM
queda
11-16-2007 08:30 AM
Slomies
01-17-2006 01:32 AM
cyrix12
08-14-2005 07:02 PM
K20 EG
06-24-2003 09:22 AM
Quick Reply: crower stroker kit vs. micropolish and balance crank?
