Help with turbocharging my h23.
ive decided i want to turbocharge my nonvtec h23. Im not too familuar with forced induction and that so if someone can give me some help id appreciate it. I dont want anything thing big. a small turbo and run maybe 6-8 psi. This is because i dont want to do any internal work and i was told i can safely turbo my car without doing any internals. Is this true? also were do i start looking for this turbo? are there companies that make them sepcifically for h23s? Also how much hp should i be producing in the end? thanks.
Re: Help with turbocharging my h23. (ludaboy93)
no turbo's were specifically designed for certain engines. for example: you could use 1st gen DSM turbos, saab turbos, volvo turbos, all on your H23. its the manifold that designates which motor it can go on.
gaaa, there's wayyy too much to explain. read this ENTIRE thread, then create a new thread IF that doesn't answer all your questions
https://honda-tech.com/zero...age=1
you can do what i did, go find a first gen junk car gank the injectors, manifold turbo, down pipe and resistor box and all you have to do is a little moding when it comes to matching the holes up on the block...im turbo with the same setup now.
