1000cc saturated injectors
Old Jul 22, 2006 | 02:18 PM
nick91civicsi's Avatar
Default 1000cc saturated injectors
i recently heard that there are now 1000cc injectors available and iv been searching around but havent been able to find anything. If anyone has and info please let me know....also, would these still be a direct replacement or would i need to do some sort of modification?
thanks
Old Jul 22, 2006 | 06:07 PM
Turbocivic94's Avatar
Default Re: 1000cc saturated injectors (nick91civicsi)
I havent seen any yet but there might be. I would just get unsaturated and run a resistor box.
Old Jul 22, 2006 | 07:58 PM
bb_one's Avatar
Default Re: 1000cc saturated injectors (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">I havent seen any yet but there might be. I would just get unsaturated and run a resistor box.</TD></TR></TABLE>
Tried and true. Plus there are an abundant source of low imp./ peak & hold injectors for great prices now-a-days.
Old Jul 23, 2006 | 07:36 AM
kamAccord's Avatar
1000cc Injectors
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jul 23, 2006 | 08:18 AM
BoostedEG6's Avatar
Default Re: 1000cc saturated injectors (kamAccord)
If you contact RC they have 1000cc injectors but I am sure your not going to want to spend around 600+ for injectors. I would run the Precision peak and hold and get a resitor box. will cost you around 300 for everything
Old Jul 23, 2006 | 09:01 AM
well i was looking for saturated for the ease of installation but im def not spending 600 for them.... looks like its time to do some more research... if anyone has any links on installing peak and hold with a resistor box i would appreciate it..
thanks
Old Jul 23, 2006 | 09:14 AM
BoostedEG6's Avatar
Default Re: (nick91civicsi)
here is the link for install
https://honda-tech.com/zerothread?id=517274
Old Jul 23, 2006 | 10:08 AM
Threads's Avatar
Default Re: (BoostedEG6)
The ease of install is not worth the trouble of the idle/low load problems with some high impedence saturated injectors. That's why you dont see many saturated injectors bigger than 750cc.
Old Jul 23, 2006 | 10:11 AM
thanks, seems easy enough....how do i know which 4 wires to splice into
Old Jul 23, 2006 | 10:12 AM
BoostedEG6's Avatar
you have to trace them with a tester (cant think of what its called right off hand.. Brainfart) and that will let you know what wires you need to tap
Old Jul 23, 2006 | 10:31 AM
ok well once you id the four from the plug, is there a certain order they should be in or is it just one wire from the box to one wire from the plug and thats it?
thanks for the help
Old Jul 25, 2006 | 06:55 PM
should i go with a certain brand? precision, rc??? and wheres a good place to order from??
Old Jul 27, 2006 | 05:23 PM
im about to order some rc injectors but im not sure if i need to purchase the different clips or not since i have a 94 teg with a 98 b18c5 with hondata, so if someone can help me out i would appreciate it....
here is the Description
RC Engineering is the world's leading supplier of made-to-order, high-performance, electronic fuel injectors. Up for auction is a set of BRAND NEW 4 RC Engineering injectors for any Honda or Acura OBD1 or OBD2. Specs are 1000cc's PEAK AND HOLD INJECTORS, LOW RESISTANCE Approx. -2.5 - 3 OHMS (MEASURED AT 43 P.S.I.G.) Part # PL9-1000. . Great for Civic's or Integra's with Turbo or any kind forced induction. Never melt a piston again! Works great on ALL MOTOR cars as well.. These retail for $98.75 plus shipping EACH! OBD2 or 1996 and + vehicles will need OBD1 Injector Connector plugs ($30 extra if needed).
Old Jul 27, 2006 | 08:07 PM
Topdawgg's Avatar
i ordered my RC 750s from ebay.... no problems... im sure there are good 1000s on ebay as well
Old Jul 28, 2006 | 03:38 AM
well my question is do i need to buy the extra clips they offer for the injectors to work on a 98 b18c5 with an obd1 ecu???
Old Jul 28, 2006 | 05:27 AM
Topdawgg's Avatar
the injectors i found worked with honda obd1 clips.... made by RC
b16bri
Sep 5, 2010 02:53 PM
spockeg
Oct 6, 2006 09:49 PM
wrestler121
Oct 15, 2003 12:31 AM
boosted_dc2
Oct 13, 2003 07:17 AM
hybridreams
Sep 12, 2003 09:22 PM
