valve spring sticking!
Old Jul 26, 2006 | 03:44 AM
turbodohcsi's Avatar
Default valve spring sticking!
anyone ever heard of skunk2, or any other, dual valve springs binding on each other?
Old Jul 26, 2006 | 02:23 PM
earl's Avatar
Default Re: valve spring sticking! (turbodohcsi)
If you mix manufacturers with your springs or don not use the proper spring seat for you install, that can happen.
Old Jul 26, 2006 | 02:46 PM
tony1's Avatar
Default Re: valve spring sticking! (earl)
Supertech had a bad batch go out and the inners were rubbing on the outers.
Old Jul 26, 2006 | 06:54 PM
well im on stock type r seats, cause i couldnt find where skunk2 made seats. but i am running the skunk2 springs and retainers, ferrea 1mm oversized intake, .5 mm oversized exhaust (the top of the class valves), ferrea guides, ferrea locks, ferrea seals... but anyways, the retainers fit the springs, and i hope the shop would of told me if the springs didnt seat on the seats properly, but i was just curious cause this is the only thing i could come up with that was a good explantaion for the problems i was having.
Old Jul 26, 2006 | 07:27 PM
marcussmith26's Avatar
If you are looking at the valve and see a small gap it could be slightly bent. I have seen valves bent slightly and you can push on the valve and close the gap check and make sure the valve is not warped. Hope this helps.
Old Jul 27, 2006 | 02:16 AM
well the head is still on the car, and i was really trying to avoid taking it off again. see the machine shop kept screwing up the guides, so i have had that thing off to many times getting the guides redone. and see i had thought about a bent valve, but it should be running perfect now if thats what it was.... i wouldnt think
Muckman
Feb 24, 2012 10:43 AM
jeb97gsr
Feb 22, 2008 12:44 PM
SupraManAG
Feb 15, 2008 08:48 PM
xQB21x
Jan 13, 2007 08:10 AM
