got a gm map sensor.... how can i know if its 3 bar?
hello everybody,
i got a gm map sensor from a friend, how can i know if its a 3 bar map?
it dosnt have any sticker on it.
but it has these # stamped on it:
c b
039 1327
and on the other side (connector side):
aa-3
thanks
c b
039 1327
aa-3
thanks
what are you using as fuel management? it should tell you (due to the breakpoints for tuning) what kind of map it is or at least the approximate "bar". anything aroung 28-32psi would be a 3 bar map. good luck bud, other than that...no idea. test voltage?
brett
brett
Re: (B18 CYA)
thanks dudes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA »</TD></TR><TR><TD CLASS="quote">1 Bar: 039, 460, 883, 876
2 Bar: 886, 012, 539, 609, 701
3 Bar: 749, 861
Therefore, you have a 1bar.</TD></TR></TABLE>
good list...
3 Bar: 749, 861
good list...
