Boost bug bit me hard....need more power!!
Old Jul 21, 2006 | 03:59 PM
Schister66's Avatar
Man U FTW
Default Boost bug bit me hard....need more power!!
I have a 99 GSR turbo right now...it was/is my first attempt at a turbo set up and is pretty basic. I had it dynoed on 9psi where it made 274.9whp and 194.4wtq.
I need more......plain and simple.
My question is....what can i do to make it faster? Where should i start?
My Setup:
1999 stock block GSR engine (62,500miles)
SPoolin performance log manifold (ac friendly)
2.5" dp and exhaust
T3/T04E 60 trim .63ar
38mm Tial WG w/ 10psi spring
Tial 50mm BOV
RC550 injectors
2.5" charge piping
HP Racing Intake manifold
31x6x3 IC
Crome chipped P28
Exedy Stage 2 clutch w/ ACT 11lb fly
What do i do to make more power?? Originally i thought of just building the engine and raising the boost, but i'm open to suggestions from those who know more than i do.....Thanks in advance!!
Old Jul 21, 2006 | 04:19 PM
Mugencrxsir1's Avatar
Default Re: Boost bug bit me hard....need more power!! (Schister66)
Upgrade the exhaust system, ramhorn/top mount header should improve top end, and a 3" DP with 3" exhaust will definately help with a few ponies and will help your engine breath. Tune the car again at 12psi, and you should break the 300whp mark, and if you upgraded the full exhaust, you will see a much greater improvement(HP).
Old Jul 21, 2006 | 04:20 PM
Default Re: Boost bug bit me hard....need more power!! (Mugencrxsir1)
Also, if you don't already, a boost controller will definately help out the cause.
jared99's Avatar
Pistons, rods, maybe a block guard, tune...then BOOOOOST!!!!!!!
65psi.
Old Jul 21, 2006 | 04:23 PM
nowtype's Avatar
Default Re: Boost bug bit me hard....need more power!! (jared99)
Increase boost....There is absolutely no reason to tear apart everything to gain more power. Just know in the back of your head that by increasing boost pressure your margin of error narrows very quickly. If you don't have a very good tuner that knows what is up, then you will blow the engine quickly.
Old Jul 21, 2006 | 04:26 PM
BoostedEG6's Avatar
I say to turn up the boost, have a good tune and upgrade to a 3" exhaust and downpipe and then later on sleeve and build for more
eshlil
Mar 16, 2007 03:51 PM
Schister66
Oct 26, 2006 12:55 PM
Schister66
May 2, 2006 09:39 AM
Schister66
Jan 11, 2006 09:52 AM
boostdummy
Oct 28, 2005 08:37 PM
