ac doesn't work with Hondata s200
Old Jul 23, 2006 | 01:47 PM
Finland's Avatar
Default ac doesn't work with Hondata s200
I installed the Hondata system a couple of years ago, when I didn't have a/c on the car..now I've re-installed a/c and the compressor won't engage.
I hook up my original ECU, the car ofcourse runs terrible, but the a/c compressor comes on.
question for Hondata-gurus
1.) could it be possible that the a/c output is disabled via Hondata?
2.) could it be possible that I have a non-a/c ecu?
3.) any ideas on a remedy besides the obvious.
I think I might just wire the compressor output to a 2 position switch if all else fails.
Old Jul 23, 2006 | 02:21 PM
Dunc's Avatar
BCICAN
Default Re: ac doesn't work with Hondata s200 (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">
I think I might just wire the compressor output to a 2 position switch if all else fails.</TD></TR></TABLE>
1.) Yes
2.) No idea (hopefully/surely others will know)
3.) Check wiring, then check the A/C tab in Hondata. You might have it being disabled starting at a very low RPM or a very light load.
Old Jul 23, 2006 | 05:44 PM
Finland's Avatar
Default Re: ac doesn't work with Hondata s200 (AF-P Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">1.) Yes
3.) Check wiring, then check the A/C tab in Hondata. You might have it being disabled starting at a very low RPM or a very light load. </TD></TR></TABLE>
wiring is OEM, not modified and AC works with the stock ECU, so I know the only issue is the Hondata ECU.
I'm going to have a friend hook up his laptop and we are going to find out if the cutoff is setup way too low.
TimiK
Dec 9, 2016 08:08 AM
chacabaca
K Series
Oct 11, 2010 07:43 AM
1greatEG
Jun 13, 2008 09:23 AM
TypeRPaul
Aug 25, 2005 05:31 PM
goose21
Apr 20, 2004 09:39 AM
