Max Current Pull of Stock ECU Injector Drivers?
Long story short...I need to know what the max current pull is of the Injector Drivers before you burn them out? Anyone know exactly?
The datasheet states 3 amps as the absoulte maximum, and I assume that is per transistor (there are four independent transistors in each STA413A). So I would try and pull no more than 2.5 amps off of each injector circuit, especially since there is no heatsink for the drivers.
chintanwall
Honda Civic (2001 - 2005)
Sep 17, 2016 01:06 AM
B_Swapped93
Apr 24, 2013 08:44 PM
