The Best Flywheel Weight?????
Old May 16, 2007 | 07:06 PM
lscivic8.5's Avatar
Default The Best Flywheel Weight?????
Hey dudes.... I need some help deciding on what weight flywheel to use on my sohc turbo setup!!!!! I have a 93 del sol with a d16z6 and I am in the process of getting the necessities to boost the stock z6 with the exception of a walbro 255,dsm 450s,fuel pressure regulator,and clutch and flywheel!!!! The car will mainly be used as a weekend warrior with the ocassional 1/8th mile run at the local dragstrip!!! I am planning on using the clutchmaster stg 5 4 puck ??? Which flywheel/flywheel weight would you guys recommend for a 7500 rev limit car in the 1/8th mile????
Any help would be awesomely appreciated
P.S. I plan to build the motor after I spin a bearing/throw a rod/blow the hg!!!!! So keep in mind that I do plan to up the boost!!!!
Old May 16, 2007 | 07:45 PM
inspyral's Avatar
Most people say not to go "too" light. I had a 12lb flywheel on my Y8 and I liked it a lot. I had a 12lb, then switched to a 7.8lb flywheel on my B18B, and I liked both. The lighter flywheel does feel a little more responsive, and I didn't really notice any change in drivability.
Old May 16, 2007 | 07:47 PM
lscivic8.5's Avatar
Default Re: (inspyral)
Thank alot for the input I want to go lighter for the responsiveness!!!! Anyone else?
Old May 16, 2007 | 08:04 PM
Jared's Avatar
go as light as possible and still have an sfi approved flywheel.
Old May 17, 2007 | 03:29 AM
lscivic8.5's Avatar
Default Re: (Jared)
Old May 17, 2007 | 12:34 PM
lscivic8.5's Avatar
Default Re: (lscivic8.5)
Anyone else?????
Old May 17, 2007 | 02:18 PM
WalkerGSR1's Avatar
Light flywheel is fun to drive with hits redline so fast.
Old May 18, 2007 | 03:28 AM
lscivic8.5's Avatar
Default Re: (WalkerGSR1)
Old May 18, 2007 | 06:23 AM
mahatma's Avatar
yeah i have a 12lb on my LS and it drives like stock.....should've gone lighter
Old May 20, 2007 | 06:53 AM
lscivic8.5's Avatar
Default Re: (mahatma)
up
bigsnorlax
Jun 1, 2011 06:45 AM
dragonjay006
Nov 22, 2009 08:03 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
lilman36
Nov 20, 2003 12:00 PM
