Block Notching, Engine still in car!?!?
Old May 18, 2007 | 06:39 PM
eleet's Avatar
Default Block Notching, Engine still in car!?!?
Alright I need to notch my d16Y8 for TT H beam rods.. Has anyone had any experience with notching the block while its still in the car?? I already am to the point.. I just need to get a long extention for the dremel so I can reach it.. Im just nervous as hell with getting shavings in the crank bearings.
Old May 18, 2007 | 07:09 PM
Sketch_hs's Avatar
dont
Old May 18, 2007 | 07:27 PM
eleet's Avatar
That helps a whole lot.. Care to elaborate?
Old May 18, 2007 | 07:35 PM
Bailhatch's Avatar
Default Re: (eleet)
i think what he meant was; do not
Old May 18, 2007 | 08:23 PM
dohcdelsol's Avatar
Default Re: (Bailhatch)
its alot easier to take the block to a machine shop and have them do it. if your experienced, you can get the correct bit and go to town but cleaning it out afterwards is gunna be a PITA.
Just go buy another seperate y8 block and build it the right way. This will save you down time with the car. and d blocks are easy to find and cheap.
Old May 18, 2007 | 08:33 PM
indicajones's Avatar
i thnk he meant do so at your own risk. or maybe he meant thats a incrediable stupid idea. dont be lazy!!!!!! good things usualy take a long time. crap comes and goes quick.
Old May 19, 2007 | 01:33 AM
Astig's Avatar
Default Re: Block Notching, Engine still in car!?!? (eleet)
Good luck with that! Do it the right way, you can either pay now or pay later.
Old May 19, 2007 | 01:58 AM
eleet's Avatar
Great picture thank you.. Anyone have more like that??
Old May 19, 2007 | 10:22 AM
CivicVX94's Avatar
Default Re: (eleet)
soo...you're putting new rods in and don't plan on taking bearing clearances? and are keeping stock pistons or do you not plan on honing the block either?
Old May 19, 2007 | 11:45 AM
kranked91dx's Avatar
dont know who the Fk tell you to do this that way but, this Rod installation must be taken into consideration seriously, it's a big part of block building and IMO, you NEED to take out the engine assembly to get that done properly.
-you will shave about 1/8 deep per 3/4 inch wide from each side of each cylinder, that will trow a big pile of shaving into your engine, and Al shaving dont wipe off easily.
-Not even discuting about the lack of precision you will get with the crank still in place...
- you need to size at least a bit those bearing with plastiguage... if you dont, it will knock and destroy itself in short period of time.
I'm in no way going to tell you how to do this, do it your way... but you will end up with a less precisely built engine, and remember Honda engine are all about clearance.
I would take the engine out, to a stand, build measure, clean each part before reassembly... new water pump, oil pump and seal to get the engine fresh and running strong.
Jp
dc2doi
Aug 8, 2007 06:17 AM
eleet
Jul 24, 2007 07:53 PM
phantom_bcw84
Jan 18, 2007 01:39 AM
AlienKrOZ
Jul 29, 2006 11:31 AM
john d
Apr 23, 2004 04:25 PM
