taping compressor housing for boost controller
Old May 13, 2007 | 06:21 PM
boost4life's Avatar
Default taping compressor housing for boost controller
ive already searched the forum and im looking for some info and opions to help me im not sure if i should run my boost controller through my intake manifold or the compressor housing from what ive learned already im fairly sure its best to drill and tapp my compressor housing for a spike free boost setup correct also what drill and tapp size should i use since i dont have a chart
i jus want to here what u guys think if running my lines through the housing will really create a more predictable spool thanks
Old May 13, 2007 | 06:40 PM
A.E Motoring's Avatar
Default Re: taping compressor housing for boost controller (boost4life)
i had mine drilled and tapped in the charge piping, the pipe that goes to the compressor housing
Old May 14, 2007 | 01:29 PM
boost4life's Avatar
should i use a 90 degree barb fitting with a 5/16 or 1/4 in barb
Old May 14, 2007 | 01:48 PM
SPOOLINmatt's Avatar
Default Re: (boost4life)
i always mget my solenoid pressure from the turbo or near it, and the boost controllers pressure from the manifold.
Old May 14, 2007 | 01:49 PM
PrecisionH23a's Avatar
edit 1/8" npt
Old May 14, 2007 | 02:40 PM
tony1's Avatar
Default Re: (PrecisionH23a)
1/8 NPT for most...
Old May 14, 2007 | 04:13 PM
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">1/8 NPT for most...</TD></TR></TABLE>
Correct... what the hell was I thinking?
Old May 14, 2007 | 05:51 PM
boost4life's Avatar
okay thank i hate to make another thread about this but ive learned everything about boostim from h-t and simliar sources im only 18 but never looked into this till ima bout to boost
so i think i will tap the compressor housing and that line will go to the side of my wastegate but first it will have my analog boost controller is between my tial wg side
thenport and the top of the wg port will go to my vacuum manifold that sounds okay
Old May 14, 2007 | 05:55 PM
boost4life's Avatar
im making this harder than really is i use a 1/8npt with a 1/4 barb for the line
wow i feel like a boost noob
Alpinestar03
Aug 4, 2008 09:51 AM
ludeDVR
Nov 6, 2007 06:59 AM
hotrod99
Jun 13, 2007 04:01 AM
wpgcivic
Aug 26, 2005 09:48 AM
Therumblingteg
Mar 2, 2003 09:20 PM
