wastegate break down
Old May 16, 2007 | 01:14 AM
Whiteintegra's Avatar
Default wastegate break down
I took apart my Tial style wastegate and now i can't put it back together. Does anyone have an install diagram for the wastegate? Im having trouble figuring how the diaphragm works inside the wastegate. I want to make sure the diaphragm and everything else works correctly before i put the wastegate in my car.
TIA
Old May 16, 2007 | 05:34 AM
under_boost's Avatar
Default Re: wastegate break down (Whiteintegra)
http://www.tialmedia.com/docum...m.pdf
Old May 16, 2007 | 08:45 AM
i already looked at that diagram. its not usefull b'c it dosent have the diaphragm mentioned in it... bump for help
Old May 16, 2007 | 08:50 AM
HiProfile's Avatar
Default Re: (Whiteintegra)
Umm... if you look at teh 'spring cup assembly', you'll notice the cup is sitting in what looks like your diaphagm. Your 'cup' has no lower lip like on that picture, therefor they have the diaphragm already attached to the cup.
Old May 16, 2007 | 12:05 PM
should i close the wastegate with the rubber lip uplike this...
or down like this..
Old May 16, 2007 | 01:49 PM
SuperTeg95's Avatar
down like second pic
Old May 16, 2007 | 04:33 PM
B18EG6's Avatar
Default Re: (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">down like second pic</TD></TR></TABLE>
once you have the top almost all the way down, peek around in there and make sure none of the diaphragm is caught. Use a soft blunt plastic object to push it into the cup if its caught
Old May 16, 2007 | 06:04 PM
tnx guys
Adam_b16a
Aug 25, 2009 03:00 PM
smnowell
Feb 5, 2005 03:26 PM
InLimbo87
Aug 11, 2004 05:58 AM
gdrum
Feb 11, 2004 01:41 PM
wrestler121
Nov 30, 2003 07:19 PM
