boostin y8 ????
Old May 19, 2007 | 05:55 PM
gsrturbo-ek's Avatar
Default boostin y8 ????
im thinkin bout boosted my y8 nd would like to nwo who much boost the stock sleeves can hold nd what are the best pistons to use. also what turbo.
kinda on a budget nd only lookin around 300whp (if possible on stock sleeves)
thanks for the help
Old May 20, 2007 | 04:24 AM
Default Re: boostin y8 ???? (gsrturbo-ek)
bump
Old May 20, 2007 | 09:15 AM
Joseph Davis's Avatar
bump
Old May 20, 2007 | 09:29 AM
aarontrini85's Avatar
if all you want is 300 then vitara pistons eagle rods and an aftermarket oil pump (stock ones suck)
it was about a year ago that we got the pump done but i think it was here that we had it done http://www.theoldone.com/compo...s.htm
the stock sleaves can hold a decent amount more then 300whp
might want to check this out it can help you alot with ideas
https://honda-tech.com/zerothread?id=1643764
Old May 20, 2007 | 04:57 PM
Default Re: boostin y8 ???? (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">if all you want is 300 then vitara pistons eagle rods and an aftermarket oil pump (stock ones suck)
thanks man yea i saw that single cam thread but mostly it was z6 that peaple used just wanted info on the y8 faster but thanks man
https://honda-tech.com/zerothread?id=1643764</TD></TR></TABLE>
Old May 20, 2007 | 05:00 PM
yeah the only real issue that the y8 has that the z6 doesnt is the oil pump every thing else is ****
Old May 20, 2007 | 06:36 PM
yea i hear alot about the oil pump crapping out thats y ill probly build the motor before boost
Old May 21, 2007 | 12:20 PM
bump
Laserjock
Oct 13, 2008 04:38 PM
RNPoo7
Jul 4, 2007 07:12 PM
damn_import_culture
May 4, 2005 01:00 PM
G3NR8
Mar 20, 2004 08:36 PM
