oil light paranoia
Old May 15, 2007 | 02:47 PM
SwappedTURBOegg's Avatar
Default oil light paranoia
Ok so im a spaz.. and my oil press light takes a bit longer than im use to to turn off.
engine specs
ross racing pistons and rings 81.5 mm bore 8.5 compression PTW clearance set at .006 ACL bearings all clearances set at .0015 GSR crank B18C1 block manley turbotuff rods ARP headstuds B16 head ITR valvetrain crower buillet CTR+ cams[stage 1 allmotor] arospeed camgears greddy timing belt.
Ive been running it all motor and have about 100 miles on it. vtec pop is loud and crisp. engine sounds very healthy. runs very strong.
I have my oil feel line for my turbo "T"eed off the oil press sender and the line is pretty long with a plug in it until the turbo goes on.
check the vid lmk is this is normal or if i need to toss a new oil pump in.
Old May 15, 2007 | 03:01 PM
Jared's Avatar
have you physically checked your oil pressure with a good gauge rather than the dummy light? what weight oil do you run? did you check the level?
Old May 15, 2007 | 03:04 PM
Default Re: (Jared)
yeah im working on getting a oil press gauge. oil level is spot on. runing 5/30
Old May 15, 2007 | 03:50 PM
Snafubmx234's Avatar
Uh... I see nothing wrong. When your oil light is on the engine hasn't even started.What's the big deal?
Old May 15, 2007 | 04:03 PM
shortyz21's Avatar
Default Re: (Snafubmx234)
u dont have a oil pressure gauge?
Old May 15, 2007 | 04:09 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 &raquo;</TD></TR><TR><TD CLASS="quote">Uh... I see nothing wrong. When your oil light is on the engine hasn't even started.What's the big deal?</TD></TR></TABLE>
watch the video
Old May 15, 2007 | 04:27 PM
m R g S r's Avatar
Default Re: oil light paranoia (SwappedTURBOegg)
yeah just get a cheap autometer mechanical gauge it's a lot more accurate than your stock one. . .
Old May 15, 2007 | 04:34 PM
Default Re: oil light paranoia (m R g S r)
CHILL its on the list boys. lol just got it ruining the past few days.
Old May 15, 2007 | 05:09 PM
Jared's Avatar
did you build a brand new engine and put a used oil pump on it?
Old May 15, 2007 | 05:13 PM
Default Re: (Jared)
got it from my buddy. it was"rebuilt"
Old May 15, 2007 | 05:15 PM
also i checked the oil a few min ago its about a half quart low. it just started taking 3 seconds normally takes 1 or less. i think its fine and just need to add some oil. im paranoid though
Old May 15, 2007 | 05:28 PM
ok i just added some oil and on a total cold start it took less than a second for the light to shut off. i think im safe. getting a real gauge soon!
Old May 15, 2007 | 05:29 PM
Mykizism's Avatar
Default Re: (SwappedTURBOegg)
just a word of wisdom here.. you can have 10 gallons of oil in your motor, and have no oil pressure. and when you have no oil pressure you have metal to metal contact in on the bearings.. and thats not good..
ps: i just watched your video.. to me that seems like a long time.. for your oil light to turn off after you start the motor
on my car, as soon as i start the motor, the oil light turns off in less than a second. in your video it seems almost like 3 full seconds there..
Old May 15, 2007 | 05:35 PM
Default Re: (Mykizism)
yet i just added some oil and it was less than a second. i dont really know why low oil could make low press. because its not that low at all. i think it has something to do with the t on the oil press sensor.
Old May 15, 2007 | 05:40 PM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">yet i just added some oil and it was less than a second. i dont really know why low oil could make low press. because its not that low at all. i think it has something to do with the t on the oil press sensor. </TD></TR></TABLE>
you are correct, oil level has nothing to do with oil pressure, except when there is not enough oil for the pick up to suck in. but having 2 -3 qts of oil vs having 5.. there should be no diffrence in pressure.
the T could have a affect on it.. but it shouldnt be much.. a dirty oil filter can cause some low oil pressure by a few psi.. not much.
Old May 15, 2007 | 05:49 PM
yeah its about time for my first oil change and the switch to syn.
now it seems fine.
Spoolinls
Jan 7, 2013 04:23 PM
PeakBoostSi
Oct 14, 2009 04:14 PM
insidiouseg-6
16
Feb 11, 2008 07:27 PM
92redhatch
Nov 26, 2006 07:39 PM
