code 3 under low boost
Old May 17, 2007 | 05:54 PM
bgtviper's Avatar
Default code 3 under low boost
just installed greedy turbo kit on 90 civic with d15b in it. only boosting 4 psi, but map code keeps coming on under hard accel. I know that I need some type of engine management unit, but the car I pulled the kit off never set that code. if you could please let me know any tips it would be appreciated.
Old May 17, 2007 | 06:38 PM
HiProfile's Avatar
Default Re: code 3 under low boost (bgtviper)
Its called a Missing Link. Its a fancy check valve for the MAP sensor. Your kit apparently doesn't have that any more. Or I'm guessing the car you pulled it from actually used more than wishful thinking to manage boost.
I can tell you this, 6psi on a tiny turbo pushed 60% more whp out of my 8.53:1 D16 over 9.1:1 stock. Ignition timing thats okay (even conservative) for 0psi is way too much for even 4psi.
Old May 17, 2007 | 06:45 PM
THEDirtyDseriesWOOT's Avatar
i have a missing link ,, 25$ shipped its 85 new
2kdrift
Feb 20, 2010 03:08 PM
sohcvtec1995
Jan 29, 2005 05:28 PM
94greddycivic
Jun 26, 2004 10:43 AM
2ltrsnailpwr
Oct 24, 2003 03:33 AM
Fatty_1775
Aug 16, 2003 12:12 AM
