How would you fix this downpipe issue?
Old May 17, 2007 | 04:26 PM
D15Bbigred's Avatar
Default How would you fix this downpipe issue?
well I'm test fitting everything and come to find out that there is no way in hell I can get a screw through this hole. It's just to tight of a fit. I can't really think of any good resolutions other than bashing the **** out of the pipe and make it work . or just cutting two parallel cuts through the flange so i can just slide a screw through. but doesn't that compromise the seal? Any helpful hints are very welcome. thnx
Old May 17, 2007 | 04:27 PM
Flexin5's Avatar
a shorter bolt maybe?
Old May 17, 2007 | 04:28 PM
D15Bbigred's Avatar
also if you thinking run studs from the exhaust housing and up. Not working allready tried that. nah shorter won't work either. Tried using a 16mm bolt thats the smallest i can use, and nothing.
Old May 17, 2007 | 04:35 PM
99B16Si's Avatar
stud
Old May 17, 2007 | 04:41 PM
D15Bbigred's Avatar
tried it, not working
Old May 17, 2007 | 04:43 PM
boosted timebomb's Avatar
Default Re: (99B16Si)
cut it, as long as the bolt still has pressure on the inside of the flange it should be alright.
Old May 17, 2007 | 04:48 PM
abnaasefmb's Avatar
Default Re: (boosted timebomb)
http://www.atpturbo.com/Mercha...e=FST
Old May 17, 2007 | 04:50 PM
D15Bbigred's Avatar
i like that atp idea, gives me some more room to work with , with it being a six. but how long is it , i wonder?
Old May 17, 2007 | 04:53 PM
inspyral's Avatar
Slot the hole.
Old May 17, 2007 | 04:58 PM
akira712's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Slot the hole.</TD></TR></TABLE>
Old May 17, 2007 | 05:32 PM
BlueSi2k's Avatar
Default Re: (D15Bbigred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15Bbigred &raquo;</TD></TR><TR><TD CLASS="quote">tried it, not working</TD></TR></TABLE>
How doesn't the stud work? Does the nut not even fit in there? Otherwise just start threading the nut as the stud is coming through.
Old May 17, 2007 | 05:38 PM
D15Bbigred's Avatar
went to checker and got those stepdowns and it worked great.. no seriously a staright up 8m stud was not workin its a a/c compatiable down pipe so the bend is tight as hell. that and the stud was too long and was hitting the downpipe. thnx for all the help guys . that was quick.lol
Old May 17, 2007 | 05:42 PM
abnaasefmb's Avatar
lol you got them at checkers! i wouldn't of thought they would have them.
Old May 17, 2007 | 05:48 PM
D15Bbigred's Avatar
local checkers ftw!!
Old May 17, 2007 | 06:23 PM
em18u's Avatar
not to sound dumb but what i did was use a short bolt which has been said but then you take a torch and get it cherry red and put a dimple in it!!!!
Old May 17, 2007 | 06:44 PM
THEDirtyDseriesWOOT's Avatar
slot the hole mine used to be like that works fine
Old May 17, 2007 | 06:46 PM
Civicman86's Avatar
I just used a stud on mine.
Old May 17, 2007 | 07:36 PM
Jared's Avatar
who made the dp?
Old May 17, 2007 | 08:47 PM
BlackBeastEK's Avatar
stud!!!! if no solution just dont bolt it but make sure the rest are, youll have a little exhaust leak
Old May 17, 2007 | 09:08 PM
playahwitgame's Avatar
Default Re: (elementb16a)
what i did was cut a little portion out, screwed the bolt into the turbo, then slipped the dp on the bolt then just kept tightening. seemed to work fine
Old May 17, 2007 | 09:17 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: (playahwitgame)
I would have said slotting the flange like mentioned or a shorter stud??? But whatever worked for you
Old May 17, 2007 | 09:48 PM
Default Re: (ForceFed_Motorsports)
yeaaaaaaa, slot the flange lol
Old May 17, 2007 | 10:15 PM
Sketch_hs's Avatar
Old May 18, 2007 | 04:23 AM
93supercoupe's Avatar
Default Re: (Sketch_hs)
crash or ruin all those hondas that say R.I.P. in ur sig?I hope not.
Ur best bet would to be slotting the flange or a shorter bolt.
Old May 18, 2007 | 04:38 AM
morgan@synapse motorsport's Avatar
slot they flange its done all the time
