Oil Return line *help*
Old May 15, 2007 | 04:43 PM
Boosted_Coupe's Avatar
Default Oil Return line *help*
UPDATE SCROLL DOWN FOR NEW PICS
Ok so I'm not to sure which way to do this. The problem that I'm running into is the my oil return fitting is about 4 inch's away from my oil pan fitting, and it's almost even with it. My Turbo sits really low, and I'm worried about the line not being a good enough slope. Plus the line would have fittings on it too right? I have a Striaght -10 fitting and also a 45 degree -10 fitting, i could use either or coming off the turbo.
Please let me know what you guys think would be the best way to do it.
Here are some pics,
Modified by SiR_JDM95 at 6:43 PM 5/17/2007
Old May 15, 2007 | 05:27 PM
khaosman's Avatar
I had a similar problem... I was able to ghetto-fit it but it wasn't pretty. I ended up relocating my drain so I could have a decent length line that worked much better.
What I would recommend is getting a premade line. Those lines you assemble yourself aren't flexible enough because the fittings have to be so much longer. Since a premade line has compressed fittings, it gives you a little more hose and less fitting which will flex a little better.
atpturbo.com sells them, you just need to how what length you need and what angle fittings.
Oh btw, I think I bought nearly every -10AN hose end and -10AN to 1/2" NPT adapter from Aeroquip trying to figure this out! I bought the Aeroquip quiklock hose (blue stuff), and it isn't terribly flexible. Plain rubber hose was a little better.
I hope you have better luck than me. Perhaps you'll find a solution that I could use as well
Old May 15, 2007 | 05:52 PM
Boilermaker1's Avatar
get some aluminum fuel line and tube nuts, you should be able to bend that pretty easily.
Old May 15, 2007 | 06:16 PM
boosted timebomb's Avatar
Default Re: Oil Return line *help* (SiR_JDM95)
wow you have almost no room i would say to lose the AN line and just do barbed fittings not as good but it might work. also what motor is that and what manifold are you using.
Old May 15, 2007 | 06:25 PM
teddy_dc2's Avatar
i had to ditch my alum. fittings for a barb like stated above. it shorted the length the fittings took and got the job done.
Old May 15, 2007 | 06:30 PM
hangac1093's Avatar
Default Re: (teddy_dc2)
I used the 45 and the the straight, It was tight but I got it to work.
Old May 15, 2007 | 06:42 PM
Hondatron's Avatar
Default Re: Oil Return line *help* (boosted timebomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted timebomb &raquo;</TD></TR><TR><TD CLASS="quote">wow you have almost no room i would say to lose the AN line and just do barbed fittings not as good but it might work. also what motor is that and what manifold are you using.</TD></TR></TABLE>
i agree
Old May 15, 2007 | 06:52 PM
bigbadboy's Avatar
use a barb fitting off the turbo and run the AN line to it and just clamp it on there. thats how i have mine done i had the same prob exept when i had both my fittings on the touched
Old May 15, 2007 | 07:53 PM
Default Re: (bigbadboy)
Thanks for the replies so far guys.
I'm not sure what Barbed fittings are, but I'm going to look into it. The manifold i'm using is a mini ram horn on a stock b16a.
Here are a few more pics i just took. I pretty much spent the whole night trying to figure out what i can do to fix the problem, but im still lost.
Here are a few more pics to give you guys an idea of how much room i have from one fitting to the other.
and here is the manifold
Old May 15, 2007 | 09:45 PM
drift2004's Avatar
Default Re: (SiR_JDM95)
push on fitting 90 and a straight
http://store.summitracing.com/...w=sku
Old May 15, 2007 | 10:27 PM
riceball777's Avatar
Default Re: (drift2004)
i had the same problem
i just rewelded a new bung on the oil pan all the way to the end of the pan which is the right side right under where the ac compressor would normaly be.
by doing that i had a lot more room to run a much longer oil return line
Old May 15, 2007 | 11:17 PM
hbboostman's Avatar
i also had the same problem with the same length restriction and AN fittings that i tried numerous times but didnt work out becuase it kept kinking the line...
i ditched the AN fittings and line...went to Napa...got Barbed fittings for both sides and got a flexible hose line that was steel braided from the inside (so it wouldnt kink) and that fixed the problem...all together both fittings and the 6 inch line cost me about 20$
Old May 16, 2007 | 01:05 AM
methos713's Avatar
who makes that turbo manifold/dump/downpipe? Looks sick. Hope you find a solution.
Old May 16, 2007 | 03:36 AM
Default Re: (hbboostman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbboostman &raquo;</TD></TR><TR><TD CLASS="quote">
i ditched the AN fittings and line...went to Napa...got Barbed fittings for both sides and got a flexible hose line that was steel braided from the inside (so it wouldnt kink) and that fixed the problem...all together both fittings and the 6 inch line cost me about 20$</TD></TR></TABLE>
See the problem is,the bung on the oil pan is 3/8 so the fitting i have on there is a 3/8 to -10. Can I get -10 to 3/8 Barbed fittings??
Old May 16, 2007 | 03:38 AM
Default Re: (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">who makes that turbo manifold/dump/downpipe? Looks sick. Hope you find a solution.</TD></TR></TABLE>
A local guy around my area made it for me. I'm happy with it so far, and his service is great with life time warranty. He is a user on here, his name is WeirTech.
Old May 16, 2007 | 04:07 PM
khaosman's Avatar
Yeah you can get a -10 to barb fitting... or just get something like this http://store.summitracing.com/...w=sku
NAPA should have 3/8" NPT to hose barb fittings.
Old May 16, 2007 | 08:43 PM
Default Re: (khaosman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khaosman &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you can get a -10 to barb fitting... or just get something like this http://store.summitracing.com/...w=sku
NAPA should have 3/8" NPT to hose barb fittings. </TD></TR></TABLE>
Thanks, I'm picking up a few different fittings tomorrow, and I will try them after work. Hopefully it all works out in the end. I'll let you guy's know what happens.
Thanks, for all the replies
Old May 17, 2007 | 05:42 PM
Ok guy's, I got some barbed fittings. I got two straights., and also 45 degree fitting to see what works best. I'm pretty sure the 45 degree with the striaght coming off the turbo and the striaght in the oil pan will work best. But let me know what you guy's think.
Notice the hose thats on the fittings is just a test hose, and is sliced open for better fitment. I do have a High Temp oil hose that i will use.
And here is just both straights, I don't think the angle will be efficient with a hose on there.
Old May 17, 2007 | 08:13 PM
Default Re: (Boosted_Coupe)
Bump.. Anyone?
Old May 17, 2007 | 08:26 PM
i dont see any reason the two straights wouldnt work but you right the 45 does give a better angle. either way the hose will probably be pretty hard to get on.
what i did with mine was unbolt the manifold off the motor with the turbo still attached, lift the manifold up a little, hook up the oil line, and then bolt it back on. that way your not taking forever to try and force the line on. just watch to make sure it doesnt kink and have extra line with you just in case.
Old May 18, 2007 | 09:29 AM
CBURKE's Avatar
Use the 45 and the str8 fittings. Clamp them down just to be safe.
Old May 20, 2007 | 12:15 PM
evans_art's Avatar
use 45 deg and 45 deg fitting
k20em2
Oct 19, 2006 07:24 PM
93turbotegSAV
Aug 29, 2006 02:44 PM
iHOPEyouCHOKE
May 27, 2006 09:24 AM
alfee
Jun 28, 2004 04:10 PM
birz
Jun 4, 2004 06:03 AM
