LSvtec Turbo build
Old May 13, 2007 | 08:53 PM
jdmkid8383's Avatar
Default LSvtec Turbo build
ok I have a b16 head I picked up for free due to exchange for labor installing a motor for a friend. I have a b18a bottom end that I want to re build for my RHD da. I have a budget of 1000 bucks I have a turbo from an eclipse I picked up from pick a part what parts should I use to make it a good and long lasting motor that will run on 7psi daily?
Help me out guys it would help ALOT...
Old May 13, 2007 | 08:56 PM
4DRmafia's Avatar
get forged pistons and rod for ur bottom end
Old May 13, 2007 | 08:59 PM
jdmkid8383's Avatar
Default Re: (Skip'sDC2)
how much for the pistons
Old May 13, 2007 | 09:45 PM
SwappedTURBOegg's Avatar
Default Re: (jdmkid8383)
psh
ditch the t25 and if you want to be really cheap. get a old T3 off a omny or something. with a cast manifold. stock block and head boost 10 psi all day every day. get some dsm 450s and a quick tune. lil rich is fine for you. 10 psi on that t3 > 7psi t25.
also turbo coupe turbos are pretty nice for what they are. or check out holsets.
Old May 13, 2007 | 11:32 PM
jdmkid8383's Avatar
Default Re: (SwappedTURBOegg)
so I can keep the stock bottom end just get her cleaned up and build the head a little bit and 10 psi would be good? Or should I build the bottom end and clean up the head and install some GSR cams how much power are we talking about?
Old May 23, 2007 | 01:43 PM
lambertincorp's Avatar
i suggest u get arp rod bolts if ur sticken with stock pistons and rods
Old May 23, 2007 | 01:49 PM
Topdawgg's Avatar
1000 for a cheap turbo setup and getting an LS/VTec in the works....
good luck... I couldnt Do it.
leroyb
Jul 11, 2008 06:18 PM
feriotypeR
13
Mar 13, 2008 12:50 AM
1.8turbolsvtec
Jan 5, 2004 02:44 PM
racerxadam
Mar 1, 2002 11:46 AM
