Which is better....
Old May 14, 2007 | 07:33 PM
Boosted_EG8's Avatar
Default Which is better....
which engine is best for boost? GSR or LS? I plan on running stock internals. And what tranny is best LS or GSR?
Modified by Boosted_EG8 at 8:45 PM 5/14/2007
Old May 14, 2007 | 07:46 PM
Default Re: Which is better.... (doood)
read it again.
Old May 14, 2007 | 09:35 PM
ProjectDarkBlack's Avatar
Default Re: Which is better.... (Boosted_EG8)
so there are over 20 million posts on Honda-tech. Who wants to bet the has been covered already?
GSR/GSR
Old May 14, 2007 | 09:43 PM
Schister66's Avatar
Man U FTW
get the GSR or build an LS/VTEC...the stock LS heads flow like garbage and is obviously a big restriction, not to mention they dont rev nearly as high....
GSR
/Thread
Old May 15, 2007 | 04:51 AM
George Knighton's Avatar
H-T Order of Merit
Cat pictures deleted.
If you guys know so much, just help the guy instead of flaming him.
If it has been posted about so much, then show him where to look.
He obviously needs a little hand.
Old May 15, 2007 | 05:07 AM
93supercoupe's Avatar
Default Re: (George Knighton)
even though GSR's have a higher compression, the potnential for power is much greater in stock form.
Revving higher is going to allow u to make more power at a lower PSI, and an 8200rev limit is fun as hell on the street.
Old May 15, 2007 | 10:48 AM
sp00led's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">get the GSR or build an LS/VTEC...the stock LS heads flow like garbage and is obviously a big restriction, not to mention they dont rev nearly as high....
GSR
/Thread</TD></TR></TABLE>
Schister pretty much sumed it up. Both the LS and GSR bottom ends are fine. The GSR vtec head is far superior and will make a lot more power.
The LS tranny is better for a daily driver or if you plan on a lot of highway use. You will enjoy the low rpms in 5th gear. The GSR tranny is going to be better for racing and imo is more fun to drive.
joewhite
Jun 15, 2004 05:29 AM
xkhalil333x
Aug 19, 2003 11:39 PM
icelarry27
Jun 4, 2003 01:07 AM
Fooser
Apr 3, 2002 10:22 PM
blazin
Mar 11, 2002 09:28 PM
