little help with ARP head stud install...
Old May 19, 2007 | 03:31 PM
Flexin5's Avatar
Default little help with ARP head stud install...
i got my ARP head studs in, and i'm about to put my new motor into my car, i just need to put the head onto the block. the ARP head studs diden't come with any of that ARP lube or any instructions....so do i just tighten them down to stock specs and can i use anything else either than the ARP lube?? TIA
Old May 19, 2007 | 05:26 PM
Legion's Avatar
* B A N N E D *
Default Re: little help with ARP head stud install... (Flexin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexin5 &raquo;</TD></TR><TR><TD CLASS="quote">i got my ARP head studs in, and i'm about to put my new motor into my car, i just need to put the head onto the block. the ARP head studs diden't come with any of that ARP lube or any instructions....so do i just tighten them down to stock specs and can i use anything else either than the ARP lube?? TIA </TD></TR></TABLE>
You can use regular motor oil as lube, because ARP has a different set of torque specs for using it instead of their moly lube. And don't tighten the bolts into the block; twist them all the way down, then back them out a half turn.
PhrequenC
Jun 9, 2008 10:55 AM
1990_integra_DA9
May 19, 2008 04:57 PM
ef8rex
Dec 24, 2003 04:32 PM
hatchy
Mar 9, 2003 01:57 PM
baonest1
Oct 17, 2002 06:29 PM
