map sensor?
Old May 20, 2007 | 09:40 AM
pjr710's Avatar
Default map sensor?
what is the purpose of the map sensor? how much is a new one? and do all turbo set ups need a new one?
Old May 20, 2007 | 10:03 AM
aarontrini85's Avatar
Default Re: map sensor? (pjr710)
if you run low boost your stock map will work
basicly your map sensor reads the amount of pressure in the manifold so it can tell how much air the motor is taking in and adjust timing and fuel acordingly
if you have a chipped ecu and need to replace your stock one becouse its broken or just not able to read the extra boost your dumping in then pick a new one up there cheap and easy to install
http://www.xenocron.com/produc...nents
Old May 20, 2007 | 12:06 PM
97Ej6mike's Avatar
Without this sensor, things go haywire, such as sputtering, misfire and bacskfiring, ruinning extremely rich, poor gas mileage, and lots of smoke, from the richness of the mix. It also can foul spark plugs, and leave a nice layer of soot on your back bumper/trunk.
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
H-allmotorda9
Feb 7, 2010 07:29 PM
EK k kay
Nov 2, 2006 01:04 PM
LSVtechnologytur...
Dec 9, 2004 04:26 AM
austrian type-R
Sep 1, 2001 05:16 PM
