fuel setup for 500 whp
Old May 12, 2007 | 07:27 AM
powerdbygarrett's Avatar
Default fuel setup for 500 whp
ok right now i just have a walboro 255 pump and i know its not nearly enough. so whats the next step, i just read about the bosch pump, is it a direct drop in pump or does it need something else. any other recomendations? thanks
Old May 12, 2007 | 07:52 AM
DaveF's Avatar
Default Re: fuel setup for 500 whp (powerdbygarrett)
actually you can get away with the walbro.
Old May 12, 2007 | 08:23 AM
1995Civic's Avatar
Default Re: fuel setup for 500 whp (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">actually you can get away with the walbro. </TD></TR></TABLE>
I second that.
You can either go with the Walbro 255lph or you can go with the Walbro 255lph HP, which is for "higher" horsepower cars. Check it out.
Old May 12, 2007 | 08:26 AM
get away? or be safe?
Old May 12, 2007 | 08:28 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">
get away? or be safe?</TD></TR></TABLE>
Both...you'll be fine.
I would also get an upgraded fuel rail w/ a FPR...and if you really want to get technical, you could also run SS braided fuel lines
Old May 12, 2007 | 08:50 AM
aight good, ive been having the fuel rail and regulator and the walboro for a while now. thanks for reasuring me
Old May 12, 2007 | 09:04 AM
Topdawgg's Avatar
walbro with FPR, Fuel Rail and 1000's and you are find for 500+
thats what im doing
Old May 12, 2007 | 02:58 PM
Adriano's Avatar
Default Re: (Topdawgg)
Walbro 255 hp, fpr, 1000ccs are enough for 600whp safely.
Adriano
Old May 13, 2007 | 04:45 PM
dpetro1's Avatar
Default Re: fuel setup for 500 whp (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">
You can either go with the Walbro 255lph or you can go with the Walbro 255lph HP, which is for "higher" horsepower cars. Check it out. </TD></TR></TABLE>
just to clarify the HP stands for high pressure and is pretty much exactly the same the the regular except that it can still flow a decent amount of fuel at 100psi and up. they both flow almost exactly the same until 60-65psi. after that the regular starts to drop off rahter quickly.
but ill agree with everyone else and say that the walbro will be fine at 500whp.
Old May 13, 2007 | 05:01 PM
Boner_Ben's Avatar
Default Re: fuel setup for 500 whp (dpetro1)
I made 570whp with a Walboro 255 HP and 1000cc injectors with absolutly no pressure drop.
Old May 13, 2007 | 05:33 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">
but ill agree with everyone else and say that the walbro will be fine at 500whp. </TD></TR></TABLE>
Right..I understand this.
I was just clarifying to the OP that they had two different versions of the Walbro out. Thanks for going into further detail though
Old May 13, 2007 | 07:23 PM
BlakeJ53's Avatar
good info
Quickgti1.8t
Dec 6, 2007 06:53 PM
JFG Kevin
23
Dec 20, 2006 01:18 AM
Lonnieboosted
Aug 13, 2006 10:31 AM
cuin9sec
Jul 31, 2006 01:43 PM
plusONE jboy
Jul 26, 2004 11:41 AM
