need headstuds for boost... but which ones for a b16b? quick answer pls
As title says. Building my b16b for boost need to know which headstuds i get?
Studs for a b18c? as its a 1.8 block
Or something else?
Please help asap
THANKS
Josh
Or something else?
Please help asap
THANKS
Josh
Re: need headstuds for boost... but which ones for a b16b? quick answer pls (J1A1H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J1A1H »</TD></TR><TR><TD CLASS="quote">
yes, b16b block is same as b18c/ITR
so that is what studs you need. in order to have proper length.
Re: need headstuds for boost... but which ones for a b16b? quick answer pls (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
so that is what studs you need. in order to have proper length.</TD></TR></TABLE>
This Info is correct. The B16B block has the same deck heigth as a B18C/ITR, the B16B is just an ITR block with a shorter stroke and longer rods
BlueShadow
11-03-2005 08:40 PM
