Oil return line help needed
Old May 15, 2007 | 06:29 AM
Mr_ET's Avatar
Default Oil return line help needed
Hey guys, I am just finishing up my turbo install and the only part left is my stupid return line.
I have the ss line that came with the stealthmode kit but I only need about 4-5 inches long and I need it to do this shape:
As you know those lines are not very flexible so I just can't get it to bend the way I need it to.
Could I use any other type of hose that would offer more flexibility and doesn't need to be purchased at a specialty store?
Please note that the hose would be close to the downpipe and the fitting going into the pan almost touches the DP. The line itself does not come into contact with the DP though.
thx for the help!
Modified by Mr_ET at 8:47 AM 5/15/2007
Old May 15, 2007 | 06:34 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Oil return line help needed (Mr_ET)
Yes you can run any high temp hose. I would also recommend some sort of heat shielding hose wrap. You should be able to get these parts at any automotive store. Are you using AN fittings or just barbed fittings and hoes clamps?
Old May 15, 2007 | 06:48 AM
Mr_ET's Avatar
Default Re: Oil return line help needed (White Smoke)
barb fittings and hose clamps
Old May 15, 2007 | 07:37 AM
i my honda
Global Mod
So i am guessing it came with braided line then? Do you know what size it is?
Old May 15, 2007 | 08:41 AM
Mr_ET's Avatar
yes the kit came with a braided line 5/8 inside diameter and the fittings have 1/2 inch ends to go into the pan and into the turbo
Old May 15, 2007 | 09:23 AM
i my honda
Global Mod
I might have some high temp line at my house I don't need. It's probably faster for you to get in from an auto parts store though. Just make sure you get some thick stuff that can withstand heat. Like radiator hose...
Old May 15, 2007 | 12:03 PM
Mr_ET's Avatar
Ill get some hose like that from NAPA tonight and I bought a fire resistant sleeve to go around it. It reflects heat up to 2000F so hopefully this all works
Old May 15, 2007 | 02:23 PM
i my honda
Global Mod
Sounds like your all set
D15Bbigred
Mar 1, 2007 07:36 PM
vladd
Aug 19, 2006 06:39 PM
themorphious
Jun 11, 2006 09:18 PM
Black R
Feb 20, 2005 03:12 PM
tslag
Nov 18, 2003 10:18 AM
