turbo timer question...
Old May 19, 2007 | 01:31 PM
blinger's Avatar
Default turbo timer question...
HKS turbo timer
does the e-brake and speed wires need to be hooked up for the turbo timer to work? Right now, when you shut the car off the timer shuts off also.
Old May 19, 2007 | 01:49 PM
Civicman86's Avatar
Default Re: turbo timer question... (blinger)
No (at least on the greddy and blitz ones you dont, so I assume the others don't either), make sure your using the right setting on the timer. I think most timers have like 2-3 different settings. The default setting might be 0sec and you don't even know it. You need to read the user guide though.
Old May 19, 2007 | 03:21 PM
blinger's Avatar
Default Re: turbo timer question... (Civicman86)
I bought the timer from H-T so I don't have a user guide with it.
I followed the picture that can be found in any of the turbo timer install threads but its not working lol.
It turns on with the car, but shuts off with the car also. We have the e-brake hooked up now and it still does it.
Old May 20, 2007 | 05:27 PM
blinger's Avatar
bump
Old May 20, 2007 | 08:56 PM
krazyhmongboi's Avatar
did you hook up just the turbo timer or did you hook it up to an alarm also?
Old May 20, 2007 | 09:17 PM
da_dude's Avatar
You need to wire it to the e-brake. Well, that is what I did to my greddy. Speed wire is not recommand it.
Old May 20, 2007 | 09:22 PM
bigbadboy's Avatar
don't need to hook up the speed or e-brake. i didn't hook them up on my greddy one
Old May 20, 2007 | 09:30 PM
the ebrake option would b a good and easy hook up because if the ebrake goes down the car dies..
Old May 21, 2007 | 05:13 AM
dfdon3's Avatar
yea e-brake and vss dont need to be connected did u hard wire it or do you have a harness?
Old May 21, 2007 | 10:27 AM
blinger's Avatar
Default Re: (dfdon3)
Hard wired.. tried hooking up the e-brake and still no go. There is no alarm
Old May 21, 2007 | 09:12 PM
blinger's Avatar
Default Re: (blinger)
still need some input
Old May 22, 2007 | 05:40 AM
dfdon3's Avatar
first did you change the setting on ur timer i know mine has AC and IG...make sure they correspond if there is a switch on the timer...if not then your wires are messed up if you cant figure out the wires i say buy a harness or look on homemadeturbo.com theres agood writeup there installing a full auto timer on a 95 civic hardwired
Old May 22, 2007 | 08:04 AM
blinger's Avatar
couldn't find the link on HMT but i'm still searching for it
Old May 23, 2007 | 07:17 PM
bigbadboy's Avatar
sounds like you don't have it wired up correctly then. go to the HKS site and down load the instructions on which wires go where and borrow a voltmeter if you don't have one. cause your going to need it to install the turbo timer correctly
Old May 23, 2007 | 08:07 PM
blinger's Avatar
Default Re: (bigbadboy)
I used a test light and couldnt get it to work. tried 4 or 5 different ways of hooking it up .. I think an H-T member sold me a non-working timer.
exotik4doorcivic
May 12, 2006 08:58 AM
phiberoptik
Nov 6, 2005 06:26 PM
ScrapinSi
Jul 15, 2003 05:49 AM
Maldo965
Nov 14, 2002 06:11 PM
