Hondata S300 base map setup stumpped
Old May 16, 2007 | 04:47 PM
VisualAutoMotoring's Avatar
Default Hondata S300 base map setup stumpped
Motor: B18C1
CP Pistons 9.0:1
Eagle Rods
RC 550cc Injectors
MSD 3 bar
Hondata S300
Ok here's the deal....
Didnt have a base map available so had to start from stratch. Plugged in 550cc, 3bar. Upload...Car wouldnt stay idled. Bump the low speed fuel map 50%. Car idles....
Hooked up PLX to ELD to datalog wideband....calibrated it close enough.... Idle reads pretty close but with some throttle goes way off....
Been spending a few days to get this car running somewhat but keep running into dead spots...
Today started throwing MAP CEL. Cleared comes back on...Switched to GM 3 bar...Same problem...Wiring is correct....
Car hits a wall @ 4000 rpm and wont do anything...
Tony1...tried that new MAP setting you told me about.....cant get it to idle even backing down almost 20%
Turbo-Charged....your inital 50% across worked good for about a day LOL
Old May 16, 2007 | 04:56 PM
tony1's Avatar
Default Re: Hondata S300 base map setup stumpped (Hybrid-Performance.com)
email me a datalog of it running and the file you have and i'll figure out what's wrong. I tried to email you a file but my email was jacked up and it kept coming back to me.
Old May 17, 2007 | 09:58 AM
Spunkster's Avatar
Try using the stock map sensor. If a map sensor is wired incorrectly it will be damaged, even if it is only for a split second.
b20turbocivic
Engine Management and Tuning
14
Dec 28, 2009 11:31 AM
JDM97R
Jul 22, 2008 09:27 PM
Turbocivic94
Jun 21, 2005 07:32 AM
FredoSP
Nov 19, 2004 07:12 AM
01ITR#700
Jun 19, 2003 02:20 PM
