Manual boost controller vs. wastegate spring
Old May 20, 2007 | 12:26 PM
slowhonduh93's Avatar
Default Manual boost controller vs. wastegate spring
Was wondering what would be more steady... a manual boost controller or a 11.46psi spring from tial... going for 300whp... stock b16, with 50trim .63ar turbo... lmk thanks Mike
Old May 20, 2007 | 12:34 PM
rextec's Avatar
you do know that you cant turn boost lower than the rating on the wastegate spring....right??????
Old May 20, 2007 | 12:49 PM
MidwestAutoWorks's Avatar
Default Re: (rextec)
Please explain how , because I just asked that in a similar thread and EVERYONES answer was no.
Old May 20, 2007 | 01:28 PM
yeah i know you can't turn the boost lower than the wastegate spring... I was simply asking if I should buy a manual boost controller or a 11.46psi spring for my wastegate... right now I have a 7.25psi spring in there... and I was asking which would hold steadier....
Old May 20, 2007 | 02:05 PM
Bailhatch's Avatar
Default Re: (slowhonduh93)
The manual boost controller will be a little more steady than just off the spring for really low boost like that. just rock the spring you have for now and get a bigger one when you want more than 300whp
Old May 20, 2007 | 02:45 PM
dpetro1's Avatar
Default Re: (Bailhatch)
yeah just grab an mbc. it will gove you a lot more flexibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">Please explain how , because I just asked that in a similar thread and EVERYONES answer was no.</TD></TR></TABLE>
everyone answered no because they are right. you cant make a spring less stiff (less boost). but you can manipulate the amount of pressure it sees, thus opening later (more boost).
Old May 20, 2007 | 09:34 PM
rextec's Avatar
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah just grab an mbc. it will gove you a lot more flexibility.
everyone answered no because they are right. you cant make a spring less stiff (less boost). but you can manipulate the amount of pressure it sees, thus opening later (more boost). </TD></TR></TABLE>
powerdbygarrett
Jul 3, 2008 01:50 PM
Jwbetley
Sep 17, 2005 11:00 AM
adamsjm5
Sep 15, 2005 06:18 PM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
