first time going boost
Old May 15, 2007 | 11:13 AM
SP GARAGE's Avatar
Default first time going boost
there is a race coming up on june 2nd at speedworld in az. i have a few spare H blocks laying around and a friend of mine has a turbo kit. now i was thinking about building a h23vtec motor that will be around 9.1 compression. my question is if i balance the motor and add rod bolts how many psi's can the stock H hold?? and will i be alright using 100 octane along with NGK 8 cold plugs? sorry for all the noob questions. i just wanted to make sure i was doing things right
Old May 15, 2007 | 11:27 AM
PrecisionH23a's Avatar
Default Re: first time going boost (mixxxwell)
https://honda-tech.com/zerosearch
https://honda-tech.com/zerothread?id=316373
There have been guys that have ran stock internals up to 500whp. If you are going past 300whp I would replace the internals with aftermarket components.
Old May 16, 2007 | 01:50 PM
hotimportcrx's Avatar
It Depends on the tune. If its for one race, well i would try to make some real power. I would run c16, make sure the timing is backed down and make sure you have no crazy cylinder temp. Just have fun. I would rev to only about 7k. If it's for one race, spare parts, you have room to play. What turbo are you using?
Old May 16, 2007 | 07:51 PM
SP GARAGE's Avatar
we are using a small turbo t3 t4. its for once race we can care less if it blows but we want atleast to make 3 good passes.
turbonitrousgsr
Oct 13, 2003 11:09 PM
Boost2NA
Sep 30, 2003 02:55 AM
boosted_zc
Mar 5, 2003 09:39 PM
Cramerox
Nov 9, 2002 04:14 PM
AbaZ
Feb 8, 2002 10:42 PM
