How much can 83mm stock sleeves hold
Re: How much can 83mm stock sleeves hold (indicajones)
I can get it tuned nicely, but I need it to last a couple of years as daily driver. Just need to know if they will hold up.
Re: How much can 83mm stock sleeves hold (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids »</TD></TR><TR><TD CLASS="quote">why not 83, a b20 is 84 bore</TD></TR></TABLE>
der der der
der der der
Re: (Del Sol on Steroids)
B20 is a completely different sleeve design from the 81mm B18's. You can't "debore" a B20 to 83mm, nor could you bore a B18/B16 out to 83mm and keep any strength in the walls. You'll oval the cylinders in short order. Stick to anywhere from 81 to 81.5 bore on stock sleeves.
nothing is guarenteed, and with stock sleeves your running a VERY big risk, and your wanting to bore to 84.5, the walls are not designed to take that much of abuse, if the motor goes lean there goes your motor, walls will crack, the thinner they go they becomg weaker, do your self a favor and sleeve it.
if you want less than 450whp, you can get that with the stock bore on the b18c and stock sleeves. the only real benefit for you going to a larger bore would probably be more torque.
you can definitely do a hone on the engine without being worried but ask your mechanic or machine shop if the block even needs a hone. its never a bad idea tho.
