Breather Question
Old May 19, 2007 | 07:24 PM
BDaTurboTeg's Avatar
Default Breather Question
I'm not using any specific breather kits or anything...
Instead i have the 2 lines coming off the back of the block into 2 seperate bottles.
My question is:
I dont have money for an breather filters for the valve cover. Can i just run the lines from the valve cover to one of the bottles or should i tee of the one line and have it run through there?
Old May 19, 2007 | 10:44 PM
Default Re: Breather Question (BDaTurboTeg)
bump
Old May 20, 2007 | 07:26 AM
bump for advice
Old May 20, 2007 | 08:06 PM
bumpy?
Old May 21, 2007 | 06:21 PM
hangac1093's Avatar
Default Re: (BDaTurboTeg)
B, a Breather filter for the valve cover is only 10 bucks at Auto Zone. But if you are venting the back of your block with the two lines, then you can run the line from the valve cover to the bottles. You just need to make sure that the bottles have some kind of vent.
You should just save $200 and buy an ENDYN kit
yyyktk1
Aug 10, 2014 04:08 PM
H1cBlacknight
May 22, 2012 02:13 AM
93egallmotor
Apr 21, 2007 01:45 PM
turbo boost
Mar 11, 2007 09:11 AM
budget
Feb 16, 2005 10:37 AM
