i have some stuff that you guys might be interested in...
Re: i have some stuff that you guys might be interested in... (TurboT)
Pivot Tach, up to 8000 rpms, has integrated adjustable shift light, easy hook up, includes
bracket - $50
it's actually, an omori gauge, not pivot... sorry
bracket - $50
Re: i have some stuff that you guys might be interested in... (dustin)
any pix of your stuff?????? A/F gauge?
[Modified by IgniteTeg, 9:00 PM 9/12/2001]
About the oil pans. How it the one tapped? For a Greddy type kit, or is it a weld on bung for a stainless line. Post a pic if you could. Also the dented one--how bad is it. Is it putting strain on the oil pump pulling the oil from the pan?
Also, will the B18C's fit on the B18B's?
Re: i have some stuff that you guys might be interested in... (93LSivic)
omori:
80mm gauge http://www.omorimeter.com/ETH-410-AZ-3_small.jpg
my gauge only goes to 8k
pivot a/f meter:
1/4 din size http://members5.clubphoto.com/_cgi-b...tem_id=1723977
shows the tach and a/f gauge in the car...
the pan is tapped on the shallow end of the pan...
if needed, you can redo the tap... on the deeper end of the pan, but the original drain fitting would have to be plugged.
the dented one is fine and doesn't affect the pick up...
not sure if it fits the b18b's without changing the pick up...
[Modified by TurboT, 7:52 AM 9/13/2001]
pivot a/f meter:
"hm...
maybe after the haltech is sold.."
That would be cool, I'm trying to make some maps available to people. If it's okay for you to make them public that is.
Jon Nelson
04-17-2006 05:22 AM
