WTF? $1300 to install haltech?
Old Sep 12, 2001 | 09:32 AM
paulzy's Avatar
Default WTF? $1300 to install haltech?
WTF....a local shop is trying to charge me 1300 bucks to install a haltech system in my car. They said it's expensive because I'm using stock gauges and lighting. I think that's a rip off. That's without the haltech system and tuning too.
Old Sep 12, 2001 | 09:33 AM
b18bturbo's Avatar
Default Re: WTF? $1300 to install haltech? (Slow_ass_4dr)
thats really high.. mostp laces charge like 300-400 dollars plus 100 for the dyno tuning.
Old Sep 12, 2001 | 09:47 AM
paulzy's Avatar
Default Re: WTF? $1300 to install haltech? (b18bturbo)
that's wat I'm saying, but this guy says that he installed Brent Rau's haltech and tuned it too. I always thought that Sean and the Extreme crew did...
Man, this thing is making me lean towards the Zdyne or hondata. Proably the Zdyne though, running a CRX now. Plug and play, but I'm worried it might not make my HP numbers that I want. 400whp with 15lbs of boost.....
[Modified by Slow_ass_4dr, 10:52 AM 9/12/2001]
Old Sep 12, 2001 | 10:49 AM
b18bturbo's Avatar
get the haltech its the way better in full tuability. Just ask Rocky he using it now. Onefastb18c.
Old Sep 12, 2001 | 10:54 AM
DirtyLude's Avatar
This guy is bullsh!tting with you. There's no changes that need to be made for the stock gauges to work. Do you have a real old car or something?
Old Sep 12, 2001 | 11:33 AM
dbman96's Avatar
New User
Default Re: WTF? $1300 to install haltech? (DirtyLude)
Stock gauges and lighting? What kind of assclown is this guy?
Old Sep 12, 2001 | 12:09 PM
paulzy's Avatar
Default Re: WTF? $1300 to install haltech? (dbman96)
it's a obd0 crx....
Old Sep 12, 2001 | 12:12 PM
b18bturbo's Avatar
that would be even easier since you dont have much to worry about... dang i dont understand why he would charger you so much,.
Old Sep 12, 2001 | 12:33 PM
VaporTrail's Avatar
New User
maybe he has no clue what he is getting into? Or perhaps he just doesn't want to do it...
Old Sep 12, 2001 | 12:55 PM
DirtyLude's Avatar
Default Re: WTF? $1300 to install haltech? (VaporTrail)
Actually I asked if it was old because I've heard of problems with stock gauges and standalones on older Honda/Acura before. I don't have any more information than that, though. I think you'd have the same problem if you went Hondata. ZDyne would have to be your option.
I'm only going off of old information here, though. If anyone else has any info, please post it, but on every Honda/Acura I've ever seen the gauges and pretty much everything other than the engine is run off of seperate controllers. The only accessory you would have to worry about is the AC.
Old Sep 12, 2001 | 07:44 PM
paulzy's Avatar
that's what I'm saying to man, but he claims that I would have to wire in the fuse panels and relays....
Old Sep 12, 2001 | 09:10 PM
Blown90hatcH's Avatar
The EF's are easier thatn the newer cars...no ABS, no cruise control...none of that...all in the fuse panel.
Old Sep 12, 2001 | 09:19 PM
dustin's Avatar
Default Re: WTF? $1300 to install haltech? (Blown90hatcH)
Haltech is pretty easy to wire up anyways once you get the ignition working right. ABS, cruise, SRS, etc are all stand alone systems on the newer cars anyways... ecm is just exactly that.. engine only But you know all this.
Dustin
Old Sep 12, 2001 | 09:29 PM
Default Re: WTF? $1300 to install haltech? (dustin)
True....you have to keep the stock ECU in the car to preform these functions. In the older style....no need.
J
Old Sep 12, 2001 | 09:38 PM
dbman96's Avatar
New User
No... you don't! Like Dustin said... ALL THOSE FUNCTIONS are controlled by separate systems. Stock ECU is shelved when you put a Haltech in.
Old Sep 12, 2001 | 09:41 PM
Explane to me what is going to controll the ABS in the car with only the Haltech?
Old Sep 12, 2001 | 09:52 PM
InfamousRS's Avatar
Im a turbo newbie, I don't even have a turbo yet, Im just getting into the research stage now. I desided that I want a stand alone, Im just starting to understand the Hondata, that was what I was planning on using. Now you guys smack me in the face with Haltech!!!! What is the difference in the two, which do you guys think is better? What is the price of Haltech compaired to Hondata???
Old Sep 12, 2001 | 10:11 PM
dustin's Avatar
You have to leave the ABS control unit in the car and powered. ABS is not controlled by the ECM, it has its own computer.
Dustin
Old Sep 12, 2001 | 10:22 PM
VaporTrail's Avatar
New User
yeap, it's located in the back seat area, behind the side panels.
Old Sep 12, 2001 | 10:39 PM
dustin's Avatar
Passenger side.
Old Sep 12, 2001 | 11:23 PM
dbman96's Avatar
New User
So there!
Old Sep 13, 2001 | 04:32 AM
DirtyLude's Avatar
Oh man, I missed all the good dialog. Really, the ECU controls only the engine and that's it. The AC only relies on the ECU to tell it wether the engine is under high load or not and if it's allowed to run. Everything else is run by seperate systems.
As for info on the Haltech, my install page gives some information and how the Haltech relates to the Hondata 4b.
http://www.hondaprelude.to/articles/inst-e6k.html
Old Sep 13, 2001 | 05:32 AM
Ubermensch's Avatar
Lude, nice site!
Old Sep 13, 2001 | 08:48 AM
smoothludey2's Avatar
New User
Default Re: WTF? $1300 to install haltech? (Ubermensch)
find another place that will install for a reasonable price, then go back to that shop, flip him the bird and drive away as fast as you can!!!
Old Sep 13, 2001 | 08:52 AM
dbman96's Avatar
New User
Default Re: WTF? $1300 to install haltech? (smoothludey2)
You'll be able to drive away faster if you wait until the Haltech is installed.
