GReddy Profec B settings
Old Sep 10, 2001 | 08:18 AM
mod5's Avatar
Default GReddy Profec B settings
Does anyone have any experience with the GReddy Profec B? This is my setup : 1999 Integra GSR w/ GReddy Turbo kit and GReddy IC and GReddy 52mm electrical boost gauge
Here is my problem: Balance **** is set right in the middle, low boost setting and high boost setting are set all the way to minimum. Even at the most minimum setting on the low boost, I am still getting .55bar (roughly 8psi). For the minimum high boost I get around .70bar (roughly 10psi). I've been playing around with the Balance **** but nothing seems to be changing.
I need some help here!!
Old Sep 10, 2001 | 08:26 AM
VaporTrail's Avatar
New User
Default Re: GReddy Profec B settings (pornstaR)
some people don't understand the balance function. Let me explain that to you.
mild = builds boost more slowly.
Sharp = builds boost more quickly
If you have it set too mild, you will over boost. If you have it set too sharp, you may not achieve or maintain your desired boost level. I have a feeling if your controller is hooked up properly, your answer lies in there somewhere.
thepariah25
Jul 3, 2007 10:11 AM
jspecegseis
Jun 22, 2007 08:53 AM
vangc6780
May 3, 2005 02:05 PM
Scean
Oct 31, 2004 06:18 PM
