Check valve setup?
Old Sep 8, 2001 | 02:23 PM
boomslang's Avatar
Default Check valve setup?
I am in the transition from selling my J&S with map limiter and getting Hondata. It might take a few weeks to get the Hondata, so I will have to resort to check valves if I want to go boosting with my car. I have never used check valves on my car, what is the optimal setup? I am NOT paying $50 for a missing link, this is only a temp fix.
-------------------Check Valve--------MAP Sensor
Check Valve
Atmosphere
Is the above right?
[Modified by Inlinefour, 5:25 PM 9/8/2001]
[Modified by Inlinefour, 5:26 PM 9/8/2001]
Old Sep 8, 2001 | 02:45 PM
5gen-hybrid's Avatar
New User
Default Re: Check valve setup? (Inlinefour)
yeah you will want to run a hose from the t/b (where the map sensor mounted) to the map sensor with check valves in between on a three way tee.i have 5 of them so i'd just start with 4-5 because they are cheap.($.49)
Old Sep 8, 2001 | 04:07 PM
JM Performance's Avatar
Default Re: Check valve setup? (5gen-hybrid)
does this system work as good as a missing link, but just uglier, or it doesn't really work as good?
[Modified by 00SilverLS, 5:08 PM 9/8/2001]
Old Sep 8, 2001 | 04:16 PM
GruvyTune's Avatar
New User
can you draw that out for us with ascii?
Old Sep 9, 2001 | 12:16 AM
integRated109's Avatar
Default Re: Check valve setup? (00SilverLS)
it kinda works, before i bought my missing link i had the little fish tank valves. in hot weather they would get stuck and cause my car to stutter, but if its only temporary it should work fine.
[Modified by integRated109, 1:17 AM 9/9/2001]
Old Sep 9, 2001 | 11:28 AM
98lude's Avatar
Default Re: Check valve setup? (integRated109)
Ryan Earl's setup is the only way to go. I tried it, and it really works. in fact, it works better than the missing link that I have right now. no hestitation in boost, never had any check engine light.
Old Sep 9, 2001 | 11:44 AM
Default Re: Check valve setup? (98lude)
Can someone explain to me that picture? Like what are the parts and what are they connecting to? Thanks.
Old Sep 9, 2001 | 04:31 PM
Honda4CX-T's Avatar
I think that's a picture of his "constructo" game set ????
Old Sep 9, 2001 | 05:10 PM
98lude's Avatar
well... it is actually pretty simple. you connect your first hose to the tb, and then fit a tee there so that the excess pressure can go straight on to the check valve, or take a 90 degree turn to the next hose. keep doing that for 3 more check valve, and link the 90 degree turn from the last tee to the map sensor.
wish there is an easier way to explain it. btw, if you look at the diagram, there are 2 places that the series of check valves links to; one on the tb, and one more above it. the one above it is connected to the map sensor.
Old Sep 9, 2001 | 05:18 PM
makes sense..........now one more stupid question.......why do you need it?
Old Sep 9, 2001 | 06:18 PM
boomslang's Avatar
If the ecu sees boost, it freaks out and goes into limp mode.
Old Sep 9, 2001 | 06:32 PM
and how do check valves prevent it from seeing boost?
Old Sep 9, 2001 | 06:46 PM
LsTurbo91's Avatar
it bleeds the air out (one way check valve) away from the map sensor
teggreen4
May 13, 2005 02:12 PM
Hybrid
Aug 8, 2002 11:30 AM
turbotec
Feb 26, 2002 03:34 PM
Teluan
Sep 3, 2001 07:29 PM
