V-AFC uses, got a question.
Old Sep 13, 2001 | 03:07 PM
VTC_CiViC's Avatar
Default V-AFC uses, got a question.
I set my V-AFC to engage the big cam at 5500 on my 98 Civic EX, I set the monitor so I would be able to see the VTi and VTo, yet they always read "off" at all times and RPM's. For those who don't know, VTo and VTi are the VTEC input from the ECU and VTEC output from the V-AFC also monitoring when there's a VTEC signal, but evidently I appear to be getting none. I appear to have everything set correctly, i've got the L-->H @5500rpm and H-->L @5200rpm, yet like I said when I monitor the sensors, I alway get an "OFF". Any idea's?
Old Sep 13, 2001 | 03:12 PM
Jared's Avatar
Default Re: V-AFC uses, got a question. (VTC_CiViC)
check and double check your wiring
Old Sep 13, 2001 | 05:36 PM
dbman96's Avatar
New User
Default Re: V-AFC uses, got a question. (Jared)
Sounds like the VTEC IN wire is disconnected from the VAFC
Old Sep 13, 2001 | 08:38 PM
VTC_CiViC's Avatar
Default Re: V-AFC uses, got a question. (dbman96)
Well I double checked them before I put everything away so I wouldn't have to go through the jungle of wires all over again, but none the less I'll make sure to check the VTEC wire again. Just seems funny that if it wasn't connected, I should be getting a CEL when the ECU see's no VTEC yet the ECU is fine.. go figure?
Power Rev Racing
Oct 16, 2005 06:10 PM
DjFreeze
May 15, 2004 08:44 AM
slowpokesi
26
May 1, 2003 08:35 PM
TurboB18C1
Nov 25, 2002 06:11 PM
rotorhead70
Oct 25, 2002 05:12 PM
