Code 1!!!!!!!!!!!!!
Old Sep 9, 2001 | 10:43 PM
therealnapster's Avatar
New User
Default Code 1!!!!!!!!!!!!!
I'm running a 95 sohc vtec block w/ 97 sohc vtec head. Ever sence the head swap I have been getting engine code 1 02 sensor. I replaced the 02 sensor with a brand new one and I still get the code, immediately after the car is started. I know I have a vacume leak at my throtle body temperarily, could this trigger oxygen content engine code 1?
-Derek-
.Afterdark.
Old Sep 9, 2001 | 10:49 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Code 1!!!!!!!!!!!!! (sohckid)
did you reset the ecu after installing the new sensor??
Old Sep 9, 2001 | 11:28 PM
zip's Avatar
zip
Make sure it's not code 10, the IAT sensor. It may not be plugged in securely.
Old Sep 10, 2001 | 11:08 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Code 1!!!!!!!!!!!!! (zip)
Code 1's well "usually" only happen after the O2 has reached operating temp, and the engine is in closed loop operation. The ECU ignores it until then.
[Modified by 88_SC_CRX_Si, 12:09 PM 9/10/2001]
Old Sep 10, 2001 | 01:50 PM
falcongsr's Avatar
What is this crap?
zip i got a code 1 or 10 this weekend...they are so hard to tell apart. i unplugged and replugged the IAT and it went away.
Joe
therealnapster
Sep 11, 2001 11:00 AM
therealnapster
Sep 11, 2001 01:58 AM
therealnapster
Sep 10, 2001 12:43 AM
