removing turbo timer?????
Old Sep 13, 2001 | 07:46 AM
bgod's Avatar
Default removing turbo timer?????
i was about to remove my turbo timer but thought to myself, would it effect the ignition system in my car. i have a 96 accord. i had the turbo timer installed with my custom kit so the shop installed it. if i were to take it off at the source of the wires will my car not start?
are the wires just spliced into the main wires?
Old Sep 13, 2001 | 08:11 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: removing turbo timer????? (bgod)
yeah...they should just be tapped into a couple of wires (six or so from what i remember). just undo the solders or wire taps. cover any exposed wires and it will be just like it was and no worries. make sure you undo the negative before you start messin.
Old Sep 13, 2001 | 08:40 AM
bgod's Avatar
Default Re: removing turbo timer????? (ho focker)
can i just cut the wires not even where they're tapped into the main wires. i just want to cut the wires and wanted to know if the car will still start.
hennessy
Audio / Security / Video
May 4, 2006 01:51 PM
92vx-t
Jan 2, 2006 10:40 AM
Z6REX-SI
Jan 5, 2004 09:22 AM
rs
Sep 22, 2003 07:50 PM
