building engines for turbo..recommandation?
Old Sep 8, 2001 | 03:39 PM
SpeedMonkeyRacing's Avatar
Default building engines for turbo..recommandation?
Ok..think it's time to start collecting parts so i can build the engine in dec. now I need to know from you turbo gurus on which parts I should get? I'm planning on boost 15psi on street and atleast 18-20 on track. I have 00' gsr w/ fmax turbo, vafc, avc-r...I have the following parts in mind and need to know the rest
-JE Pistons 9:0:1
-Crower Connecting Rods
-Portflow Inner Valve Springs w/ titanium retainer <~already have it
-Skunk2 Camgears <~already got it
-Either Hondata or Power FC
Intake/Exhaust Cams?!? Which one should I get?
Flywheel..which brand?
blah blah blah
Let me know!!!!
Jeff-
Old Sep 8, 2001 | 03:48 PM
accordv6lx's Avatar
New User
Default Re: building engines for turbo..recommandation? (ProjectD2-Jeff)
I know you want to go fast but if you are gonna be boosting 18~20 lbs of boost, then you seriously have to start thinking about cooling. I suggest you to do something with the thermostat and all other like oil cooler and what not. See ya
Joon
Old Sep 8, 2001 | 05:05 PM
FAST94GSR's Avatar
New User
Default Re: building engines for turbo..recommandation? (accordv6lx)
if money is an issue stick with the stock flywheel but upgrade your clutch. if iti isn't a issue then go with a lightened one like a jun that'll help ya spool up faster but for the money i'd put it into something else like an exhaust or better wastegater or injectors or whateva. everything looks good, from what I've seen go with hondata. don't worry bout the cooling thing that that guy said. they are nice but not needed. stock gsr cams are fine.
[Modified by FAST94GSR, 9:05 PM 9/8/2001]
Old Sep 8, 2001 | 05:20 PM
Tomakit's Avatar
Default Re: building engines for turbo..recommandation? (FAST94GSR)
Pistons, Rods, Radiator, Fans, Thermostat, Sleeves, Freshen up the head, Re-sleeve, Hondata, (actually hooking up your exhaust so you aren't running around with an open dp for the rest of the car's life... ), better clutch, slightly lighter flywheel while ur at it.
Tom
Old Sep 8, 2001 | 05:38 PM
Default Re: building engines for turbo..recommandation? (Tomakit)
haha....i have clutch specialities stage 2...prolly need another one if i want to boost 15 streetable I think i'ma go w/ power fc because i don't like the idea of carry laptop around
Jeff-
Old Sep 8, 2001 | 05:39 PM
wastegate..i have tial
i was thinking about jun flywheel too...
jnjectors...i'm talking to ben about it already
and as for buidling...prolly gonna take it to drt for that
Jeff-
Old Sep 8, 2001 | 07:27 PM
DamonBoost's Avatar
New User
Make sure getting Hondata is a priority... or any other stand alone...
Old Sep 8, 2001 | 10:36 PM
Turbo00's Avatar
New User
Default Re: building engines for turbo..recommandation? (ill logic)
higher compression like 10:1 since your getting a stand alone you'll be able to tune it better and get more power out of it with less boost
Old Sep 8, 2001 | 10:49 PM
B18C-RnVA's Avatar
New User
Default Re: building engines for turbo..recommandation? (Turbo00)
bigger injectors and stock gsr cams or turbo cams
Derek Towner
Jan 28, 2019 07:13 PM
lilshady6796
24
Feb 8, 2010 05:48 AM
Nautica_97gsr
Jul 9, 2007 08:24 AM
tegdude227
Mar 30, 2007 05:02 AM
quickLSt
Jul 19, 2001 09:25 PM
