18g
Old Sep 10, 2001 | 09:40 AM
B18C-RnVA's Avatar
New User
Default 18g
I was wondering about the 18g turbo. whats the max psi you can run on it before it desent make anymore power and falls on its face. Also if i bought a greddy kit could i swap out the greddy turbocharger for a garret one say t3/t4
Old Sep 10, 2001 | 09:42 AM
hybrid_eg's Avatar
Default Re: 18g (B18C-RnVA)
i think i posted a similar question long time ago.. but didnt get many replies.. but from my understanding you will need to get a t3/t4 turbo, new manifold, and downpipe then the only thing really left from that greddy kit would be the piping, and that black box right? plus you will most likely have to modify the piping in some way to make it fit.
Old Sep 10, 2001 | 09:53 AM
B18C-RnVA's Avatar
New User
Default Re: 18g (hybrid_eg)
hmmm alright, well whats the max power can a 18g greddy kit make. im looking for big numbers, the engine is already built up. say i run 15-20psi and get the hondata what type of numbers am i looking at?
Old Sep 10, 2001 | 10:31 AM
JimmieD's Avatar
I am thinking of doint the same kit with the hondata. From all the research i have done it seems as though 300-350 WHP is attainable with no problems. I am still checking into the wastegate issue to see if it will give me any problems at higher boost levels. I think i should be okay considering the DSM guys get away with it quite easily. I would also appreciate some more input though.
Old Sep 10, 2001 | 11:54 AM
boost killz's Avatar
New User
Default Re: 18g (lsinteg)
From what I was told the max psi reccomended for the 18g is about 16 psi which is easily good for about 320-330 hp. After 16 its just stressing the turbo and eventually blow the seals.
Old Sep 10, 2001 | 12:32 PM
bigTom's Avatar
Default Re: 18g (boost killz)
the 16g is good up to 22psi... i would therefore guess the 18g is good good up to as high if not more
Old Sep 10, 2001 | 01:31 PM
JimmieD's Avatar
Default Re: 18g (ek9t)
i wish i could find some definite answers about boost levels and the internal wastegate. anyone have any DSM buddies with the greddy upgrade. it uses the same turbo. i can not seem to find anyone with it on the boards though....anyone else?
Old Sep 10, 2001 | 01:48 PM
hybrid_eg's Avatar
there was a guy that just recently posted in this forum.. has this same kit on an ITR.. with headgasket.. and power fc.. at 14lbs turned 300+hp.. i'm looking to build a very similar set up on stock internals w/less boost.. i only plan on 8lbs.. 10 max..
Old Sep 10, 2001 | 01:55 PM
hybrid_eg's Avatar
btw, from my understanding the wastgate that comes to this kit.. max is set at .5bar.. which is little over 7lbs.. someone please correct me if i'm wrong.
My friend had this kit on his bone stock 96 gsr 4dr.. and the car ran 14.5 with a slipping clutch.. barely limped home after the 1st run.. that was done on 17's, full interior.. etc.. plus he couldnt drive for ****.. so i assume it could have been a high 13's easily with a race clutch and good driver. Honestly i'm not looking for major power in my case at least not anytime soon.. as long as i pull 220+whp i'll be happy.. cause with 5k it will be a bitch to make that power N/A.
wfocrx
Oct 4, 2007 05:05 PM
iheartEP3s
Sep 20, 2005 12:12 PM
BEEYOND
Aug 13, 2004 09:00 AM
JDM_EH2
Mar 1, 2004 04:21 AM
jazz215
Mar 11, 2003 07:01 PM
