Black Smoke???
Old Sep 9, 2001 | 12:23 AM
Pro-Lude's Avatar
Default Black Smoke???
Is it Normal for black smoke to come out when the car is boosting? I notice it today when i was following my wife when she was in my car. And what type of smoke is it? TIA
Old Sep 9, 2001 | 12:30 AM
MiraiZ's Avatar
Default Re: Black Smoke??? (Pro-Lude)
running too rich...
Old Sep 9, 2001 | 07:45 AM
HokieITR's Avatar
New User
Default Re: Black Smoke??? (MiraiZ)
Yep, definitely running rich. That's not a bad thing at all. If you want to take a little of that richness away you can get a different disc for the fuel pressure riser, or get an adjustable fuel pressure regulator. Richness just pretty much equates to slight power loss, but on the safe side.
Old Sep 9, 2001 | 08:07 PM
Pro-Lude's Avatar
Default Re: Black Smoke??? (HokieITR)
Ok well i have the MF2 system the thing is they are set all the way down. Oh well i am just hanging on untill i can go hondata and get rid of this problems.
Old Sep 10, 2001 | 05:51 AM
MiraiZ's Avatar
The MF2 is known to to make the system run a bit rich. How badly are you trailing smoke? If its just puffing in between shifts and at hard boosting, I wouldn't worry about it too much....if its a freakin chimney on wheels, then maybe some other tuning is necessary..
Old Sep 10, 2001 | 11:01 AM
88_SC_CRX_Si's Avatar
New User
Running rich is not a good thing, when it washes the oil off your cylinder walls, and scuffing starts to happen. It happened to mine, back when I was running rich.....
Old Sep 10, 2001 | 10:08 PM
Pro-Lude's Avatar
just between shifts and at hard boosting
Old Sep 11, 2001 | 12:59 AM
Reid's Avatar
Global Moderator
Hahahahahahahahaha... that was a good one.
Old Sep 11, 2001 | 01:19 AM
MiraiZ's Avatar
NA cars even puff black smoke between shifts (no big deal) If youre kickin up smoke only at heavy boosting, the I think youre fine....I would worry only if th smoke was blue or white...or if you were smoking at idle...
[Modified by MiraiZ, 7:19 PM 9/11/2001]
Arsenal
Apr 30, 2003 04:09 AM
ZoNe_HKS
Feb 11, 2003 06:52 PM
Smashback
Aug 24, 2002 01:26 PM
InfamousRS
May 23, 2002 01:17 PM
echo999
Jan 12, 2002 03:43 PM
