CEL with test pipe. how to trick the 2nd o2 sensor?
Old Sep 12, 2001 | 02:39 PM
Ri5e's Avatar
Default CEL with test pipe. how to trick the 2nd o2 sensor?
Alright, I have a problem. i have a test pipe and the o2 sensor is just sitting there breathing all the lovely fumes from the downpipe.
When I drive it normal, no problems. Or if i take it up to like 10 PSI for 2 seconds and shift, no problems. But if I take it to max boost and leave it there for like 5-6 seconds, the CEL light comes on. I think because it's reading "RICH". Then the car bogs like crazy in 1st because the ecu is making the engine run reallly rich. I reset the ECU. Works fine, then when I run it hard again, same problem. Only happens when I leave it in full boost for a while.
Anyone have any "TRIckS" to trick the 2nd O2 sensor? I tried wrapping Aluminum foil, but that thing FLIES off the o2 sensor and out of my exhaust.
Thanks.
Old Sep 12, 2001 | 04:02 PM
GSRwBOOST's Avatar
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (BG Boost)
i have a test pipe on since the rebuild and o2 sensor is pluged in and zippied to the shift linkage.. no check engine light yet... *crosses fingers*
Old Sep 12, 2001 | 06:30 PM
HXMan's Avatar
Summit sells a secondary O2 sensor "fooler" for later model GM's.
It is a direct plug in for them, but from what I could see in the pic the connector had 4 prongs...so that means 4 wire O2 sensor the same as honda. So you could buy that and your trouble will be over after a little solder and rewiring.
Or, find some way(using radio shack parts) to feed a constant .1-.4 volts when the car is running to the O2 sensor signal wire. I assume that is prolly what the Summit gadget does.
[Modified by HXMan, 9:31 PM 9/12/2001]
Old Sep 12, 2001 | 06:52 PM
Liltrix's Avatar
Are U sure the problem lies with the O2 sensor?, The CEL can be caused by the map sensor reading boost instead of vacuum.
Old Sep 12, 2001 | 06:58 PM
dustin's Avatar
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (Liltrix)
The "fooler" circuits actually oscillate pseudo-randomly back and forth between voltage levels. If you give it a solid voltage, it will eventually throw a code.
Old Sep 12, 2001 | 07:41 PM
smoothludey2's Avatar
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (dustin)
godspeed motorsports has a test pipe with a bung for the O2 sensor....apparently the bung has cat material in it so it fools the O2 sensor into thinking that you have a cat. www.godspeed-motorsports.com it has 2.5 inch flanges, perfect for turbo dp.
Old Sep 12, 2001 | 08:09 PM
Ri5e's Avatar
I think i'll try that method of just letting it hang loose lol....
Old Sep 13, 2001 | 05:59 PM
earl's Avatar
All the second O2 sensor does is measure how good the cat. is working compared to the reading off of the first O2 sensor. Try splicing the wires to the second O2 sensor into the wires of the first O2 sensor.If it throws a code on you, it will just mean that the cat. isn't working good enough but wont throw you into a limp mode. It worked for me.
Old Sep 13, 2001 | 07:50 PM
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (earl)
Actually for the 96 OBD2 you can leave it hanging outside of the exhaust system...just wrap it in something that will keep it warm.
Old Sep 13, 2001 | 09:42 PM
paulzy's Avatar
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (smoothludey2)
what about converting to obd1??
Old Sep 13, 2001 | 11:15 PM
VaporTrail's Avatar
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (Slow_ass_4dr)
I've found that to be the best solution
Old Sep 14, 2001 | 04:42 AM
GSRacer's Avatar
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (VaporTrail)
i wraped mine in foil paper. it works best. i have a question though.... what if the o2 sensor gets wet?? since it's only ziptied there. will it get damaged???
Old Sep 14, 2001 | 05:47 AM
Evil DOHC's Avatar
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (GSRacer)
GSRacer: And who told you that trick?
EVIL
Old Sep 14, 2001 | 08:10 AM
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (Evil GS-R)
the O2 sensors work on heat, so as long as it's as warm as the exhaust pipe, then you shouldn't have to worry about water, it'll evaporate faster than you can say smooth.
Old Sep 14, 2001 | 10:40 AM
VTC_CiViC's Avatar
Just out of curiosity since I plan on adding a test pipe to my Civic when I get the larget DP, what kind of zipties do you use to secure the O2 to the pipe? I'd assume the regualr zipties would melt right off so what are you using? I was intending on having a bung welded onto the test pipe to I could screw y O2 in place but now i'm not so sure if I should leave it outside or inside.
Old Sep 14, 2001 | 03:52 PM
GSRacer's Avatar
New User
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (VTC_CiViC)
evil: your sister told me that trick!!! eh eh eh eh jk
he doesn't have a sister. Yes, people... master Evil gave me all the specs on how to do the trick.
Old Sep 14, 2001 | 06:22 PM
New User
vtc civic, contact godspeed motorsports...they have a test pipe with an O2 bung sticking out of the pipe to counter OBD2...check the pic at http://www.godspeed-motorsports.com under 'other parts' there is a picture of it. I believe it fits all integras and civics with 2.5" flanges, perfect for your dp.
Old Sep 14, 2001 | 06:25 PM
dustin's Avatar
smoothludey2:
It does not matter whether the second o2 sensor is in the exhaust stream, without the cat the ECU with throw a CEL. The secondary O2 sensor is used to measure how well the cat is working. You are better off with it exposed to open air, so the ECU thinks your cat is working REALLY well.
Dustin
Old Sep 14, 2001 | 09:02 PM
Ri5e's Avatar
I've tried the Foil method. The exhaust flow will eventually tear it apart.
Old Sep 15, 2001 | 07:05 PM
New User
friendly dustin,
obviously you haven't taken a look at the test pipe at godspeed motorsports, it was designed and manufactured specifically not to throw a CEL. At least for preludes, the 96 OBD2 you could run the secondary O2 sensor outside of the exhaust system. With the 97+ OBD2 it's not that easy to run a test pipe as the secondary O2 sensor is much more sensitive (to the temperature change as exhaust flows through the cat) so it can't be placed outside of the exhaust system. The godspeed test pipe has a special bung with cat material in it so the secondary O2 won't throw a CEL. That's godspeed's solution to 97+ OBD2....unfortunately, they only make it for civics and integras
Old Sep 15, 2001 | 07:16 PM
mike's Avatar
H-T Order of Merit
obviously
Old Sep 15, 2001 | 09:27 PM
wwcivic's Avatar
New User
I have a 99 civic ex, my secondary o2 sensor is zip tied to the shift stabilizer bar. The check engine light did come on when i did this. However, after resetting the ECU the light is off and has stayed off. I havent had any problems what so ever, and I have been running the car pretty hard now for about 2 weeks. I guess i should keep my fingers crossed.
Old Sep 16, 2001 | 12:21 PM
HXMan's Avatar
Default Re: CEL with test pipe. how to trick the 2nd o2 sensor? (wwcivic)
It really isn't a big deal...the only problem with a CEL for your secondary O2 sensor is having to look at the damn check engine light all the time! I hate it!!!! (oh, I got code 63 and 91 right now just to let you know)
I was driving around with no O2 sensors for about 2 months...due to code 1, the primary and seconday O2 sensors are disabled by the ECU.
I got 28-32 mpg, and ran consistant 15.3-15.5's at the track(with P72 ECU). I pulled my plugs too and they were PERFECT. This is with a b16a2.
I just fixed my code 1 recently, and have not had a chance yet to see if my fuel economy is suffering....I bet fuel economy may have been sacrificed to decrease emissions....I don't know if this is possible, but 28-32 mpg seems to be very good milage for a mostly city driven b16. My original engine only got a few better MPG...and it was rated 35 city, 41 highway.
Old Sep 16, 2001 | 07:36 PM
nutsack's Avatar
i had a problem with my ecu throwing a "insufficient catalyst" code. the way i fixed it is i cut the ecu "memory" wire going to the ecu. since it takes 2 seperate driving periods for the ecu to realize that there is a problem with the cat, everytime i turn the car off and on it thinks its the first time it's seeing the problem with the cat. sounds confusing, but it works.
95acuraintegra
Jan 8, 2009 04:54 PM
Hyper2k
Feb 14, 2007 10:13 AM
b16wannaride
Sep 16, 2002 12:02 PM
sivicman
Jun 2, 2002 11:09 AM
comptechgsr2000
Apr 25, 2002 09:26 PM
