AIR/FUEL GUAGE
Old Sep 13, 2001 | 07:04 AM
whagkangmakulet's Avatar
Default AIR/FUEL GUAGE
My autometer air/fuel guage recently stop working! When I start my car i can see the light for about 0.5s and it is very dim...then that's it! Anyone have the same problem before? ...sorry about this ...This is a Double!!!!
[Modified by whagkangmakulet, 4:05 PM 9/13/2001]
Old Sep 13, 2001 | 07:30 AM
VTC_CiViC's Avatar
Default Re: AIR/FUEL GUAGE (whagkangmakulet)
As a matter of fact, for the past week or 2, my autometer A/F gauge has been acting nuts. It's lights up the entire gauge dimly with a certain section bouncing back and forth like normal or it'll just show only lean and stoich, with the reading never getting to "rich" like it used to. I checked the connection to the ECU and it's solid, still does it. Maybe I should check the ground?
Old Sep 13, 2001 | 07:51 AM
onefastb18c's Avatar
Default Re: AIR/FUEL GUAGE (VTC_CiViC)
Throw the guage away and get an EGT...that way you know for sure how your air/fuel ratio is...and you will know if your getting close to a meltdown.
Old Sep 14, 2001 | 09:39 AM
supadupamikey's Avatar
my gauge just started doing this crap today. it used to always read a few greens at WOT, now it keeps bouncing around at WOT like it always does.
gots me kinda worried...
Old Sep 14, 2001 | 12:23 PM
Dravis's Avatar
New User
Default Re: AIR/FUEL GUAGE (lilmikey77)
Mine did this for awhile....moving it to the actual O2 sensor wire in the engine compartment/by the downpipe solved my problem.
Alex
Old Sep 14, 2001 | 10:13 PM
FAST94GSR's Avatar
New User
Default Re: AIR/FUEL GUAGE (Dravis)
those autometers are pieces of sheeeeeeeeeet. I have a Halmeter AF30 and it works pretty good. much more accurate.
Old Sep 15, 2001 | 12:18 AM
sporter's Avatar
New User
I have had bad luck with auto meter. I had the air/fuel which did exactly what youres did. I checked everything. Finally I took it out of the car. I need to get an EGT next. Also I have the oil pressure gauge. Well doesn't do crap anymore but light up. Once again checked all the connections. POS imo.
Old Sep 15, 2001 | 05:15 AM
92CivicSiR's Avatar
New User
Default Re: AIR/FUEL GUAGE (sporter)
I don't know what your guys problems are, all of my six autometer gauges have been in the car for quite a while without a single problem. I guess it just happens to some people, and not to others.
RedTegLS
Dec 28, 2003 11:30 PM
R@mon
Sep 30, 2002 07:41 PM
Kp_VtekNiks
May 14, 2002 10:40 PM
