What does the car do when it detonates / pings? How does it react?
Old Sep 16, 2001 | 10:12 PM
DamonBoost's Avatar
New User
Default What does the car do when it detonates / pings? How does it react?
When those two things occur what does the car do? Does it make a loud noise? Does it miss? Does white smoke come out of the exhaust? Can you detonate once / ping once and not mess up your engine? Thanks.. I NY
[Modified by ill logic, 1:12 AM 9/17/2001]
Old Sep 16, 2001 | 10:25 PM
hobo79's Avatar
New User
Default Re: What does the car do when it detonates / pings? How does it react? (ill logic)
i believe you will hear some punching sound......like something is popping inside the fuel tank. like a push of some sort. correct me if i am wrong.
Old Sep 17, 2001 | 05:33 AM
RGAZ's Avatar
New User
Its a light knocking noise on heavy load acceleration that gets louder the heavier the load. Technically, it is not a miss since the cylinder fired. White smoke is coolant burning or water vapor and does not tie itself to ping unless you blew the headgasket. You can detonate a little bit and the engine will survive, its the incessant knocking that will do damage. I would recommend NEVER allowing detonation if you can avoid it.
Randy
jaypapes12
Jun 13, 2013 02:22 PM
skimeast1982
Apr 13, 2006 05:57 AM
aziantegger10
Sep 19, 2005 07:04 PM
94gsr18kid
Dec 28, 2004 07:22 PM
SIK IN DA HED
Oct 16, 2003 02:31 PM
