Which clutch to buy?
Old Sep 16, 2001 | 09:53 PM
PressurizedSi's Avatar
Default Which clutch to buy?
Now with my turbo kit installed, its only a matter of time before the 'ole clutch gives out. I narrowed it down to two brands, ACT and Clutchmasters. I know ACT is very popular, but I like the idea of the carbon-kevlar disc material used in Clutchmasters stage 3 units. My requirements are smooth engagement, holding power, and longivity. Which brand would you guys reccommend and why?
Old Sep 16, 2001 | 10:16 PM
VaporTrail's Avatar
New User
Default Re: Which clutch to buy? (PressurizedSi)
I'd go with Clutchmasters stage 3 or a clutchnet stage 2
Old Sep 17, 2001 | 01:02 AM
Anthony K's Avatar
New User
Default Re: Which clutch to buy? (VaporTrail)
I'd try to find out if you can get the Clutchnet stage 2 clutch upgrade for 300dollars from that Drag Turbo groupbuy without having to buy the turbo. I think it holds 300lbs. of torque and several people like em. When I talked to Ben from importparts.com, he said that it has a stock pedal feel but that it grabs like hell.
Old Sep 17, 2001 | 05:21 AM
RGAZ's Avatar
New User
Here is what I would do:
Get the ACT HD PP and the Clutchmasters Kevlar disc.
The ACT can hold over 200ft-lbs and the disc will give you extra wear.
I have the ACT with the street disc which is basically a stock disc that is thicker and the HD PP. it is rated to 225ft-lbs. Before, I had a stock clutch and I could slip it really easy at only 7psi (about 160 ft-lbs).
Randy
full Circling
Feb 5, 2008 01:44 PM
hondaracin24
Feb 13, 2006 01:42 PM
TEG777
Sep 14, 2005 08:49 AM
hi mom
Jul 2, 2003 04:35 PM
boostin b16
Mar 10, 2003 03:14 PM
