Recommended break in for turbo.
Old Sep 14, 2001 | 12:38 PM
JM Performance's Avatar
Default Recommended break in for turbo.
Whats the recommened break in period for a new turbo?
Old Sep 14, 2001 | 12:54 PM
b18bturbo's Avatar
Default Re: Recommended break in for turbo. (00SilverLS)
nothing really. just make sure you prime the turbo and off you go. there is no really break in period for turbo like there is for clutch. always let your motor run for while before you shut it off to let the oil flow or else you can cause oil build up in the lines. Also remeber to have a nice straight oil drain line without any kinks. The kinks will cause oil backup and blow your sealsout.
Old Sep 15, 2001 | 04:25 AM
IgniteTeg's Avatar
Default Re: Recommended break in for turbo. (b18bturbo)
Quote: always let your motor run for while before you shut it off to let the oil flow or else you can cause oil build up in the lines.
I was wonderin a turbo timer would remedy this right?? Isn't that what a turbo timer does??? Thanks for any help. Or you are refering this as a non turbo timer?
Old Sep 15, 2001 | 05:12 AM
92CivicSiR's Avatar
New User
Default Re: Recommended break in for turbo. (IgniteTeg)
Yes, he is reffering to a car that DOES NOT have a turbo timer. If you have one, then just set it up and it will do the work when you shut your car off. You are absolutely correct, a turbo timer lets your car run after you pull out the key so hot oil does not crud up in the turbo or the attatched lines.
Old Sep 16, 2001 | 11:23 PM
threatcon13's Avatar
New User
Default Re: Recommended break in for turbo. (92CivicSiR)
the drag instructions say to break it in for 1000 miles..is that wrong?!?
Old Sep 16, 2001 | 11:52 PM
PureTeg420's Avatar
Default Re: Recommended break in for turbo. (turbo01gsr)
It's good to take it easy right after the installation to make sure that everything is working alright. If you accidently make one mistake during the installation (like installing a fuel pump backwards, which i think someone from here did) then go boosting right away without knowing....you will have a blown engine in no time.
nicktagz
Sep 10, 2006 07:38 PM
delsoldrew
Sep 4, 2006 12:56 PM
kj98r
May 16, 2004 03:16 PM
threatcon13
Dec 3, 2001 12:40 AM
