Checking Ignition Timing Before the Dyno
Old May 29, 2004 | 02:19 PM
FredoSP's Avatar
Default Checking Ignition Timing Before the Dyno
I recently went to Pep Boys and bought a timing gun.
My question is, when the gun is set to 16 degrees advanced, I see the white mark line up with the notch, but when I clear out the 16 degrees from the gun (0 degrees) I see the red mark line up. Is this the way everything should be on a stock B16A2? I'm just making sure everything is golden before I go to dyno.
Here's the video, half way through I cleared the timing to 0 (on the gun) and you'll see the white mark jump to red. You need Quicktime, also make the video double size (it will help to see).
http://198.38.12.245/~fred/civic_time.MOV ~ 2.2 MB
Let me know what you think, thanks.
Old May 29, 2004 | 06:07 PM
norcalcrx's Avatar
Default Re: Checking Ignition Timing Before the Dyno (FredoSP)
Looks like it is right on. Thats how it should be.
Old May 30, 2004 | 07:28 AM
FredoSP's Avatar
Default Re: Checking Ignition Timing Before the Dyno (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it is right on. Thats how it should be.</TD></TR></TABLE>
thanks, anyone else
Old May 30, 2004 | 07:40 AM
TurboBumblBee's Avatar
yep..
when you have the gun at 16 degrees its getting the timing off the spark plug, same as when you have it set to 0 its getting signal from the plug that this is 0 so the light is gonna flash at whatever the gun is set at..
blackbndt
Oct 4, 2009 10:20 AM
Blackice087
Mar 21, 2008 06:40 PM
d15b7racer
May 7, 2006 04:10 AM
FredoSP
May 30, 2004 08:42 AM
Eric R
Jun 12, 2003 05:11 AM
