turbo gsr not starting after install??? HELP
I have just finished the install on my integra and it won't turn over at all?? I made sure the plug wires were in the right sequence and checked the plugs for the smell of gas, which it had a little. So i let the plugs sit and put them back in and tried to start it again, it sputtered a little like it was about to start but still didn't> i have tried that 2 more times with no luck. Has anyone else had this problem?? I would be much appreciative if someone could help me with my delima thats been goin on for 2 weeks now!!!!
Re: turbo gsr not starting after install??? HELP (99gsr-t)
are you using a resistor box w/ your injectors?? not sure what your setup is but i was running an oem resistor box and i had the negative and positive sides switched by mistake
Re: (turbopro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopro »</TD></TR><TR><TD CLASS="quote">theres no resistor box on a 99 integra for one, or u running a msd by chance maybe the wires inside the dist are grounding out</TD></TR></TABLE>
for being a self-claimed "turbopro" you should know that obviously he wasnt talking about a stock resistor box. but one that was wired to work with low impidence injectors.
Landon
Landon
Re: (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE>
Thanks Landon
Thanks Landon
New User
whats the setup? how long has the car not been started? when i finished my setup it was a weak battery that caused it not to start
Re: turbo gsr not starting after install??? HELP (integrx)
-weak battery (just get a buddy to jump you or charge it up)
-check for spark in your plugs (turn key over while one spark plug is out, check for spark)
-check all your wiring (I had a map sensor disconnected which caused me to run like **** and barely be able to start)
just try and narrow things down. Check your distributer (could be the coil, cap, etc). I replaced a ton of **** when I was trying to figure out my problem. Trial and error I guess....it was a pain in the *** for me but in the end I was happy, despite the money I spent. Its probably the most simple thing imaginable....
i ♥ my honda
Global Mod
Global Mod
Is it a greddy kit or what??
You need to give us more info if you want to get you car to run..
If your running a missing link I would put a dollar down that you installed it backwards
Let us know
Let us know
Re: turbo gsr not starting after install??? HELP (si2die4)
Yes i'm using a resistor box from an old crx. I have msd sci ignition also. This is my setup:
Skunk2 IM
Msd sci
msd superconductors
ngk plugs
arp head studs
block guard
compression reducing HG
sfp manifold
t3/60-1 garret
sfp IC pipping
sfp FMIC 32.5x12x3
Tial 38mm wg
Greddy type r bov
holly 750cc injectors
resistor box
AEM fuel rail
Walbro fuel pump
Hondata s200W/ boost
obd2 to obd 1 harness
p28 ecu
3inch exhaust
2.5in downpipe
Have avcr and profec 2b boost controller(just don't know which one to hook up)
When one of my friends from the local shop put my msd box on i saw that he had the dist. cap off and was messing around with it, so i'll try and check that today
Skunk2 IM
Msd sci
msd superconductors
ngk plugs
arp head studs
block guard
sfp manifold
t3/60-1 garret
sfp IC pipping
sfp FMIC 32.5x12x3
Tial 38mm wg
Greddy type r bov
resistor box
AEM fuel rail
Walbro fuel pump
p28 ecu
3inch exhaust
2.5in downpipe
Wow....did anybody read that he said it wasn't turning over. I'm no car expert but wtf do spark plugs have to do with the car turning over. Sounds like maybe a dead battery.
Re: (hoggy)
I have a chip that Frank Smith from sfp sent me for the hondata that incorperates the injector size and all. The car actually has a good battery too. How would the starter be effected if i have never had a problem with it before??
Re: (99gsr-t)
did u recently install the msd ignition? do you happen to know if the box was used or did u buy it new? have you tried swaping out a differant external coil?
Re: (Dturbocivic)
Yes it was brand new when i got it. But the thing is i have spark, so how would that effect the coil if it is already firing okay. I spoke with Frank at sf performance and he said if my hondata LED was flashing that was were the problem would be. When i tested it again after i spoke to him, he was right it was flashing. i'm goin to try and get with him tomorrow and see if we can work it out. Does this sound like a familiar problem that has happened to you turbo guys in the past???
civicgsr2004
09-25-2005 09:19 PM
caliprelude3087
07-14-2004 12:56 AM
