Spark Plug Gap???
Old May 27, 2004 | 06:05 AM
ChadB's Avatar
Default Spark Plug Gap???
I was wondering if anyone changees their gaping on the spark plugs.. When the car is supper charge or turbo.. Please help me out.. Thanks
Old May 27, 2004 | 06:08 AM
FOrSfEd's Avatar
Default Re: Spark Plug Gap??? (ChadB)
Good gap for forced induction is .028-.030. I have mine Gapped at .030
Old May 27, 2004 | 06:15 AM
-iLLuZioN-B18C1's Avatar
Default Re: Spark Plug Gap??? (FOrSfEd)
mines at .028
Old May 27, 2004 | 06:24 AM
sway892's Avatar
Default Re: Spark Plug Gap??? (-iLLuZioN-B18C1)
.030 is whats recommended when boosting, and make sure you get NGK's
BCPRES-11. They're cold spark plugs and I love them.
Old May 27, 2004 | 10:30 AM
ChadB's Avatar
I had a set of NGK and fouled them out.. I just bought a set on Denso... So 30 should be good...
Old May 27, 2004 | 12:01 PM
hypa's Avatar
Hold on here.....
What motor are you talking about?
Because the GSR needs a minimum of .050" or else you'll get some serious stuttering, and the b16 is recommended to run an .044"
WTF motors are you guys running .028" on?
Old May 27, 2004 | 12:43 PM
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">Hold on here.....
WTF motors are you guys running .028" on?</TD></TR></TABLE>
gsr
Old May 27, 2004 | 07:51 PM
sway892's Avatar
Default Re: (hypa)
Were running FORCED INDUCTION cars here, no matter what honda engine you have. Some where between .028-.030 gap is recommended for turbo's. Stock NKG's for a Gsr .052 and stock b16 NGK's .044.
Hypa get you a set of stock plugs for your turbo car, retard the time by 4 degrees after it's been on stock timing, gap your engine size .044 or .050", put your car in 4th gear and try to drive it, with the timing and gap like that. You will be going nowhere fast trust me!!
Old May 27, 2004 | 07:58 PM
Kataku2K3's Avatar
Default Re: (lexvdub1)
On high boost we've had to go down to 0.018" (seems insanely tight huh) but in general anywhere from 0.022-0.030" even with higher power 150mJ+ ignitions.
Old May 27, 2004 | 08:35 PM
Turbo E's Avatar
Default Re: (hypa)
I say 0.030" or less. turbo p3nz j00 Hypa
Old May 28, 2004 | 01:28 PM
hypa's Avatar
Default Re: (Turbo E 604)
Sup E!!!!
I'm going to have to mess around with my gaps after reading this.
I'm sitting at about .050 right now, and it finally idles properly, and makes wicked power all the way through (dyno'd in 4th gear).
I guess all setups are different.
Old May 28, 2004 | 01:56 PM
Quad-Damag's Avatar
Default Re: (hypa)
.28 runing cool
stage 1 or stage 2 colder NGK
all the way
Old May 28, 2004 | 03:41 PM
Charles B.'s Avatar
Default Re: (Quad-Damge)
i run bkr7e's at .030
Old May 28, 2004 | 07:46 PM
Garcia-Racing's Avatar
ngk 8's @ 0.026
Modified by TGARCIARACING at 3:30 PM 11/19/2004
Old May 28, 2004 | 08:23 PM
SOHC Gord's Avatar
boosted id go 25-30
Old May 31, 2004 | 10:04 AM
Vtec92Civic's Avatar
Default Re: Spark Plug Gap??? (SOHC Gord)
hows everyones idle . . . is it 100% smooth or does it kinda go . . . . bum bumu bum like it's mis-firing or anything?
I miss having a 100% smooth idle
Old May 31, 2004 | 10:08 AM
FOrSfEd's Avatar
Default Re: Spark Plug Gap??? (Vtec92Civic)
My idle is straight.
Old May 31, 2004 | 11:14 AM
smooth idle
Old May 31, 2004 | 08:16 PM
VDoP-B18C1
Guest
Posts: n/a
Default Re: (TGARCIARACING)
does gap effect idle?
Old May 31, 2004 | 08:20 PM
patdemps's Avatar
Default Re: (CharlesInTurbocharge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CharlesInTurbocharge &raquo;</TD></TR><TR><TD CLASS="quote">i run bkr7e's at .030</TD></TR></TABLE>
exactly what im running in my gsr...idle is perfect
Old May 31, 2004 | 08:39 PM
V-SPEC 1's Avatar
Default Re: (patdemps)
I use 28 gap on my 7's NGK plug.
Old May 31, 2004 | 08:51 PM
FredoSP's Avatar
Default Re: (boostedb20vtec)
Stock B16A2 plugs should be gapped @ .051", not .044" that's for D16Y5, D16Y7 and D16Y8.
Helms 96-00 page 23-111
Again this is for a STOCK car otherwise .028"-.030" is what I use
Old May 31, 2004 | 08:52 PM
fastludeh22's Avatar
.028-.029 on zfr7f's 452whp@19#'s
Old Nov 19, 2004 | 11:42 AM
quicksol95's Avatar
Default Re: (fastludeh22)
.028 gapped
bkr7es-11 s
dsm plugs is this bad?
Old Nov 19, 2004 | 11:47 AM
InTeGrA B18b1's Avatar
Default Re: (slow90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow90hatch &raquo;</TD></TR><TR><TD CLASS="quote">.028 gapped
bkr7es-11 s
dsm plugs is this bad?</TD></TR></TABLE>
no thats good
Avg .028-.030 bkrte11 1 step colder. or gapped smaller then that for hp setup's. done
