sensor pointed at my timing belt broke...can i drive without it?
my timing belt broke while driving as some of you guys already know. when i went to go replace it i noticed that my old timing belt wrapped around the sproket and tore the sensor off. my motor is a b18b1. id like to get answers asap since im doing the timing belt as we speak.
Re: sensor pointed at my timing belt broke...can i drive without it? (98B00STED)
i dont think so , that is your crank angle sensor pritty shure it will not run with out it.
Re: sensor pointed at my timing belt broke...can i drive without it? (B18C1CYA)
I got an extra crank sensor off a 00 SI that will work, let me know if you need it.
Re: sensor pointed at my timing belt broke...can i drive without it? (SOUNDEFFECTS)
You don't really need it. The obd1 cars don't use it, and they work fine.
Re: sensor pointed at my timing belt broke...can i drive without it? (m R g S r)
that is because the obd1 cars used a cam angle sensor instead
as far as I know the obd2 cars have to have it.. why not replace it while you have it apart anyway
kobeRy_si
06-06-2005 03:59 AM
