Errr...why me
To make a long story short. I was having trouble getting the skunk2 cam gears at tdc to route my timing belt and to have the crank pully right. MY dad and I fought 5 long hrs with it. Lol, it sucked
we never did this before so dont flame.
How does this look...look tdc to you??
Thanks
*** Thanks for kwuaymaikrup help for this job**
Modified by redturbocivic at 12:40 AM 5/27/2004
Modified by redturbocivic at 12:41 AM 5/27/2004
we never did this before so dont flame.How does this look...look tdc to you??
Thanks
when i did my timing belt. i had everything lined up. but after i tighten the belt as per the directions in the helms, the intake side was off by 1 tooth. i found this out after i put everything back, started the car and it did not idle right.
i took everything off and just turned the camgear counterclockwise 1 tooth before i tighten up the tensioner and it was all good.
How much have you milled off the head and off the block? I think for each .012" it throws the belt off one degree. The only way to fix your problem is with adjustable cam gears. You will be advancing both cams an equal amount until your crank gear lines up at the tdc mark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">How much have you milled off the head and off the block? I think for each .012" it throws the belt off one degree. The only way to fix your problem is with adjustable cam gears. You will be advancing both cams an equal amount until your crank gear lines up at the tdc mark.</TD></TR></TABLE>
Nothing milled off the head. Nothing milled off the block that I know of. I just got back from you with it being assembled. I have the skunk2 cam gears. Are you saying just loosen the 6 bolts to the cam gears. Move them till they are lined up??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">
.... Are you saying just loosen the 6 bolts to the cam gears. Move them till they are lined up??</TD></TR></TABLE>
no do not do that....that is used for tuning..not aligning
HBK
Sep 1, 2005 09:37 AM
